Sounds like the same sort of kit, ctek actually make the charges for a lot of big brands plus BMW, Merc etc etc. But with a top-end ctek costing the same as a decent battery with a 5 year warranty it's a questionable cost/benefit in some ways TBH.Number5 wrote:Cheers. my charger reads it as it has a 4 stage LEd indicator, it also says it trickles once fully charged, but its not a CTEC.Ewazix wrote:That would probably be OK at a low rate but not at full whack which could result in plate damage. The latest ctek smart chargers 'read' the charge state and adjust charge rates, apparently a normal charge-up will only take a battery to 80% or so although it will indicate 100%. You can try it, when you leave a freshly charged battery for a few hours the charge dissipates away from the plates in to the liquid/gel and will then accept more charge giving the impression it has discharged a bit, but this is normal. The ctek reads this and feeds more in as and when. Secondly some ctek use a pulse discharge/charge cycle to help de-sulphur plates effectively restoring them (sulphation is caused by allowing a battery to become discharged).Number5 wrote:Has anybody used a standard battery charger and just put it on a timer pkug to charge for 1hr a day ?
Would that cause any issues ?
The battery in my car is now 13 years old and still good, probably as a result of the ctek - but I'm probably tempting fate
Using battery trickle charger over winter
- Ewazix
Re: Using battery trickle charger over winter
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
Novice question
I have a Z4 E89 and want to use a trickle charger using the positive point in the engine bay. Where do people connect the negative clip to.
Any exposed bit of metal should do the job...it should all be earthed.
there are some large nuts on top of the diagonal strut braces that are in a handy spot.
2010 E89 sDrive 2.3i Alpine White
- Zed Baron
Ive got mine setup like this
- 20190208_164709.jpg (354.32 KiB) Viewed 4034 times
Zen Baron, thanks for the photo which is really helpful.
Now I have located the negative terminal I realise the distance between the pos/neg clips on the Ctek charger I have brought is too short
- road warrior
I note many of you extend the mains cable and then worry about something going wrong like cut cable. I extend the12v lead. Safer and cheaper. Use 2 core white and you won't forget it's there either.
If you ever think I'm off my rocker.. Just put me back in it and walk away... It's the kindest thing
My wife says I never listen - or something like that.
gone but not forgotton -Mean Steve - made a sound like a bear with his nuts in a trap.
- Silverzedtom
I Picked up a solar charger a couple of weeks ago when my old battery bit the dust. No cables to worry about no good inside of course
E85 2.5si
F55 Cooper S
F55 Cooper S
If only the cigarette lighter socket were live!
Vidi, vici, veni
- Silverzedtom
There’s always the OBD port, or feeding a cable through the firewall.
E85 2.5si
F55 Cooper S
F55 Cooper S
- NickDE
They are on BMWs.Silverzedtom wrote: ↑Sat Feb 09, 2019 12:07 pmThere’s always the OBD port, or feeding a cable through the firewall.
There's always the cable CTEK supply that attaches to the battery and gives a convenient socket to connect to in the boot.
Darkness gone, go Darknes2, go Frozen, go Tronic
- Tinker15
I use a CTEK and bought one of these http://www.allbatteries.co.uk/comfort-c ... x9049.html which gives you a bit more length.
- 60948144-D5F5-4936-A3A4-B17038E68319.jpeg (388.02 KiB) Viewed 3976 times
- ronk
The handbook in my car says connect to the posts under the bonnet - they must have their reasons !
- road warrior
- road warrior
i imagine is more component safe- not gonna upset the sulky airbags and such this way
- Mr Tidy
Mine is too, but that's because E85/86 ones are!
E89 ones obviously aren't - my E91 lighter socket isn't live either.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
