Wind noise from either window, despite doing a window reset?
sk93
Post by sk93 » Sat Feb 14, 2015 11:57 pm
So a coupla people here know I've been struggling with solving the wind noise coming in from my passenger window.
the problem seemed to be that no matter how much I reset the window electronically, or adjusted it via the adjustment screw accessible from under the door, it never sealed properly and I was ALWAYS getting wind noise.
well, whilst replacing my regulator this weekend, I decided it was high time I sorted this once and for all!
I learned a lot, and I'm going to dispense this knowledge as a list below.
Hopefully this will help other members in solving all types of wind noise!
1: Window Reset Procedure #1
Try this first - it fixes most problems and is the quickest / easiest to try
Code: Select all
1: Put key in ignition and turn to position 1 (lights/radio on, but NO dash lights)
2: Push and hold down the open window button (do one window at a time)
3: Once fully open, KEEP the button depressed for between 5 and 10 further seconds (do not release the button between step 2 and 3)
4: Pull and hold up with close window button until the window fully closes.
5: Release button and turn off ignition
6: Turn ignition back on and check window operation.
7: Repeat for other window if required.
2: Window Reset Procedure #2
Incase the first doesn't work!
Code: Select all
3: Once fully open, release the button, then depress four more times within ten seconds of the window fully opening
4: Close window partially
5: Push and hold down the open window button until the window fully opens
6: Pull and hold up the close window button immediately after the window fully opens
7: Once fully closed, continue to hold up the close window button for 2 more seconds then release
8: Immediately repeat steps 5 to 7 one more time
9: Turn off ignition
10: Turn ignition back on and check window operation
11: Repeat procedure for other window if required
3: Adjust rake angle of window glass
Try this if the front of the glass is lining up perfectly, but the rear doesn't appear to be high enough to make a seal along the top edge.
OR, if the rear of the window is too high and is stopping the front of the glass from fully closing.
Code: Select all
1: Lower the window fully
2: Open the door
3: Look under the door and locate the rear-most plastic cover (it is oval in shape)
4: Remove the grommet
5: Inside you will find a small adjustment screw about two inches inside the door - NOT the 10mm nut!
6: Rotate this screw clockwise to raise the rear of the glass / anti-clockwise to lower the rear of the glass
7: Re-raise the window fully during the adjustment to check alignment
8: Replace grommet
4: Adjust camber angle of window glass
Try this if the glass is either pushing up too tightly to the seal, stopping it from closing properly.
OR if the glass is not pushing up against the seal sufficiently enough to cause a good seal.
Code: Select all
1: Close the window fully
2: Open the door
5: Inside you will find a 10mm but (with the window up, you wont see the adjustment screw, so you can't get it wrong ;))
6: Loosen this bolt so that it is free to spin, but don't take it off
7: Using a flat-blade screwdriver, gently prise the loosened nut and stud either towards the outside of the door (if the glass is not close enough to the seal), or towards the inside of the door (if the glass is too close to the seal)
8: Re-tighten the nut
9: Close door GENTLY and check alignment.
10: If the glass is too close and appears to bend slightly whilst closing the door, you've pushed the nut/stud too far towards the outside - adjust it back immediately WITHOUT closing the door, as you risk the glass shattering..
11: Once alignment is complete, ensure the nut is fully tightened
12: Replace the grommet
5: Adjust the castor angle of the window glass
Use this if the glass appears to either be too far forward in the door, or too far back
Code: Select all
1: Open the window approximately half way (if you have a convertible, use the "open roof" button, as this will perfectly position the window for you!)
2: Remove the door card (plenty of guides here) - no need to remove airbag, and you will want to keep the power on, so don't disconnect it either.
3: Peel back the foam protector in the bottom rear corner of the door (it's held in place with butyl tape - use a sharp knife and be careful!)
4: Locate a large circular hole in the frame, (has an approximate diameter of 1.5 inches)
5: Through this hole, you should be able to feel the rear window lifting cradle.
6: in the center of this cradle is a large black bolt, with a female torx 45 head
7: If this screw is not perfectly accessible via the hole, either raise or lower the window slightly until it is.
8: loosen but do NOT remove this bolt. You are able to get your hand around to the back of this bolt and feel when it is almost undone.
9: With the bolt loosened, grab hold of the window glass and pull it either towards the rear of the door, or push it towards the front of the door.
10: Once adjusted, re-tighten the cradle bolt.
11: Repeat adjustment as required.
12: Once final adjustment is complete, tighten cradle bolt fully
13: Re-attach foam protector to the door (if you didn't destroy the butyl tape, heat it up slightly with a hairdryer and it will become sticky and pliable once again)
14: Re-attach door card
Now, BMW suggests that instead of what I've listed in step 5, you actually remove the outer door handle, and undo the same bolt from the outside.
This does work, and will allow approximately 5mm more of movement of the window, but it does require a special tool in order to remove the door handle correctly.
My recommendation is that you try step 5 first, and if that doesn't work, either buy the special tool from BMW, or (and it's probably cheaper!) take it to BMW to adjust..
Hope this helps others as much as it's helped me!
:zzzz:
Bing
Re: Wind noise from either window, despite doing a window re
Post by Bing » Sun Feb 15, 2015 12:13 am
This should be in the how-to section titled "Window Adjustment - wind noise" or something. Great post Ian :thumbsup:
Current... Silver Grey ///M Roadster, non-flimper spec, Imola Red nappa, permanent ear-to-ear grin 8)
Chii
Post by Chii » Sun Feb 15, 2015 1:40 am
What a write up!
Will give it ago tomorrow
Thanks for this SK!
Bumpy
Post by Bumpy » Sun Feb 15, 2015 4:55 am
=! :thumbsup:
Bumpy
Adam D
Post by Adam D » Mon Feb 16, 2015 8:28 pm
Awesome guide! Will finally tackle my passenger window which is a little low at the rear edge :thumbsup:
Silver Grey 2007 Z4MR which needs to be driven more :evil: :P :cool: :D :thumbsup:
Scooba_Steve
Post by Scooba_Steve » Mon Feb 16, 2015 8:51 pm
Great detail, I'm sure this will prove very useful :)
MrPT
Post by MrPT » Wed Feb 18, 2015 11:32 am
Nice work! This will help a lot of people. :thumbsup:
Might be worth also including the door adjustment process here as well - where you unbolt and move the latch hoop. I've seen a couple of examples of people thinking they had a window problem but actually it's their door that has slipped out of alignment with the rear flank. Mine was about 2mm proud when I bought the car and resolving this fixed the passenger-side wind noise.
2006 Z4 2.5si: gone
hopz121
Post by hopz121 » Wed Feb 18, 2015 12:02 pm
Excellent write up, would be a great idea to have these in the how to guide as others have suggested :D
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
Number5
Post by Number5 » Wed Feb 18, 2015 12:36 pm
Very detailed. Excellent contribution. Well done & Thanks.
Alpina Roadster #307
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
10x E85 Se/Si Roadsters
2x E89's
owm
Re: Wind noise from either window, despite doing a window reset?
Post by owm » Thu Mar 10, 2016 3:50 am
Thanks for this! It helped in my DIY session to readjust the rake and camber of the door glass to achieve a tight seal to eliminate cabin wind noise at high speeds :)
Picture shows the 10mm nut that is to be loosened to adjust the glass camber.
The Torx adjustment screw that controls the rake of the glass is on the right.
1977 Alfasud Sprint
1988 Mercedes Benz W126 300SE
1991 Mazda MX-5
1996 Rover Mini Cooper
2003 BMW Z4 3.0i
DonkeyKong
Post by DonkeyKong » Tue Jun 21, 2016 11:17 am
Bump
2004 E85 Stirling Grey 2.5L.
Very much original spec apart from roof motor relocation and non run flats.
Not too mechanical savvy so just enjoying the experience.
Ducklakeview
Post by Ducklakeview » Tue Jun 21, 2016 12:01 pm
I also used this guide to stop wind noise on my passenger window after replacing the cable. The noise was also present before the cable went, but gone now!
Mike
hughmungus
Post by hughmungus » Tue Jun 21, 2016 6:45 pm
Another quick fix is to pull the rubber seals that run along the folding roof bit off and pad them out with strips of polystyrene tiles, there is an how to on YouTube somewhere, I did it and it has cured the wind noise for now
Z4 Sapphire Black 2.0 M Sport ,Z4 Sapphire Black 2.5 Si :thumbsup:
stevecbrz4
Post by stevecbrz4 » Fri Feb 03, 2017 12:00 am
Very helpful thanks. :D
Z4 2.5si. Addictive straight six howl. Montego Blue. 18" 135Ms. M pack. It has to be a roadster.
Lanky Lancs Lad
Post by Lanky Lancs Lad » Fri Feb 03, 2017 12:57 am
Great, thanks :thumbsup:
3.0si Roady '07 Individual Model,
He who has most toys wins....
