Soft top open & close whilst driving
Hello,
Does anyone know of a mod that will allow the soft top to be opened & closed whilst driving at low speed, invaluable when it starts raining and your in slow moving traffic?
In my previous S2000 this could be done quite simple by cutting the speed sensor wire to the roof control (only 1 wire), thus being able to open/close at slow speeds.
- hopz121
Re: Soft top open & close whilst driving
Not that im aware of, you need to be stationary to start the procedings you can move slowly whilst it is going up though (after it has started)
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
- Angie4m
No mod but you will need a gap-Tech which will allow this as well as some other features I believe.
http://www.z4-forum.com/forum/viewtopic ... a#p1079427
Deep Sea Blue sDrive35is - I LOVE IT! Best car I've ever owned - Gone
RRS V8 Supercharged - Gone
Abarth 595 Competizione - Gone
Yas Marina Blue M4 Coupe - Gone
Current:
Protonic Blue i8
Amethyst 997
F56 JCW Challenge (19 of 52)
Still Shy and retiring
Current:
Protonic Blue i8
Amethyst 997
I have the Gap-Tech that was fitted to my zed from the previous owner but it only operates remotely from outside the car i.e. 3 presses to open/close.Angie4m wrote:No mod but you will need a gap-Tech which will allow this as well as some other features I believe.
Is there a way to mod so that it can open & close on the move?
- hopz121
Nope it doesn't work using a gap techZikim wrote:I have the Gap-Tech that was fitted to my zed from the previous owner but it only operates remotely from outside the car i.e. 3 presses to open/close.Angie4m wrote:No mod but you will need a gap-Tech which will allow this as well as some other features I believe.
There must be a speed sensor input to the roof control, as the zed has to be stationary to open/close the soft top to begin with. On the S2000 the car had to be stationary and have the handbrake on to start the open/close process and just by cutting the speed sensor wire, open top motoring on the move was possible.
Does anyone know if there is a speed sensor wire and where this is to disable/cut? Anyone done it?
- Ewazix
I doubt there is a dedicated 'speed sensor wire' to cut, the roof module will talk to the ECU for a whole range of data including speed. So (and I'm talking with zero knowledge here so shoot me down) I'm guessing if it was possible it would have to be via code to increase the max permitted speed for roof operation. I thought it was 3 or 5mph as standard but I can't imagine BMW have given it the facility to up it.
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
+1 Spot onhopz121 wrote:Not that im aware of, you need to be stationary to start the procedings you can move slowly whilst it is going up though (after it has started)
Z4 E85 SILVER 2.2 SE
Fighting to keep my Z alive - Stay tuned
- Zulu4
Reviving this thread as I read that the Porsche 911 996 cabriolet just needs one wire cutting (the speed sensor wire going to the soft top controller) to allow the roof to be raised & lowered when the car is in motion with the handbrake on the first notch. The Boxster can similarly be modified by simply bending the speed input pin of the roof relay.
Does anyone know for sure whether there is a similar dedicated speed input wire or pin on the Zed, or is the speed fed in to the controller via the CAN bus ?
2007 3.0si Auto Sport Roadster. Whippy.
Previous:
2003 3.0i SE Roadster. Whippy.
Previous:
- tomscott
With gap tech mine will shut when moving slowly (I have a feeling its like 10-15mph) but it's so slow that it's kind of pointless. Either way I still need to pull over.
http://gap-tech.co.uk/rchp.html
The reason why you cant put it up and down is the way the roof operates it acts like a wind sail as it raises so high and will break the roof if operated while driving.
- Zulu4
I did have a gap-tech but it went bad and it took me a while to figure out what was happening, so I don't really want one again.tomscott wrote: ↑Fri May 19, 2023 9:45 am With gap tech mine will shut when moving slowly (I have a feeling its like 10-15mph) but it's so slow that it's kind of pointless. Either way I still need to pull over.
The SmartTop STLFBW7 looks better, but expensive.
I'm not wanting to move the roof when at speed , just when slow in town etc.
Previous:
Previous:
- tomscott
Its probably because the standard install the wires clip over the wire insulation if you solder it in properly its far more reliable!Zulu4 wrote: ↑Fri May 19, 2023 10:17 amI did have a gap-tech but it went bad and it took me a while to figure out what was happening, so I don't really want one again.tomscott wrote: ↑Fri May 19, 2023 9:45 am With gap tech mine will shut when moving slowly (I have a feeling its like 10-15mph) but it's so slow that it's kind of pointless. Either way I still need to pull over.
- Chris_D
First world problem.
I'd suggest the inability to open/close the roof while moving is a designed-in aspect of the roof operation, probably based on potential damage that can be caused to the mechanism with a sudden jolt or heavy inertial load on any of the pivot points.
When you look at the mechanism of the E85 roof this theory bears out by virtue of the fact that it looks 'weak' in comparison to some other roof mechanisms on other cars.
A benefit of its' relatively weaker construction as designed is the fact that it is probably a damn sight lighter than other roof mechanisms.
Just pull over and raise/lower when stationary to avoid any issues. Easy.
- NaweedMustafa
Something i always thought about as well. Now that the weather is getting better, i need to remove my hardtop and enjoy the softtop. Didnt know about the gaptech solution. Should i use my own wireclips if theirs is unreliable?
Current: 2003 3.0is | Sterling Grey | Dream Red
Previous: Bicycle. Never owned a car before
- Zulu4
Gaptech is good when it works.NaweedMustafa wrote: ↑Mon May 22, 2023 7:53 pm Something i always thought about as well. Now that the weather is getting better, i need to remove my hardtop and enjoy the softtop. Didnt know about the gaptech solution. Should i use my own wireclips if theirs is unreliable?
It wasn't the wiring that caused my problem, but the internal electronics that started to fail intermittently.
Previous:
Previous:
