Well on the plus side, you can't be far from Ross at RBM, so you know you'll get good workmanship and diagnosis.
Warning Lights - DSC Sensor/Alternator
- enuff_zed
DSC Sensor Issue - FIXED
- flimper
I'm still with Will at TWG
Piano black & black extended leather. Power mirrors, tinted glass, PDC, Prof hi-fi, CD, retro-fit cruise
- enuff_zed
Oh, ok, fair enough. I admit I'm not au fait with him, but your continued patronage must mean something.
Hope you get it sorted.
Try to change battery or and voltage regulator, I know sounds stupid but that was the case for me
- flimper
The battery should be OK, only replaced it a few months ago
- Mr Tidy
If Will has read the codes and it's showing a DSC fault it looks like you may need another one.
When my battery died last year I got the same three amber lights after jump-starting it. Ross read the codes and reset the steering angle sensor setting and they have stayed off since then, but I think there are a few other problems that can cause the same 3 lights to come on.
Good luck getting it sorted.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- flimper
Thanks, I think it's moisture that has got in again, I'm tempted to see if it dries out and the problem goes away over the warmer months
- flimper
DSC Sensor Issue
When this happened first time around I had three warning lights, this time four, anyone help?
- IMG_20220302_154209.jpg (85.77 KiB) Viewed 644 times
- enuff_zed
DSC Sensor Issue
When I had all four it turned out to be an ABS sensor on the wheel, front left in my case.
That could be a cheaper answer for you? My code reader showed up which one was the issue.
- flimper
DSC Sensor Issue
OK cheers, I've noticed light steering, did you suffer from that at all?
- enuff_zed
DSC Sensor Issue
Nope. Trying to work out what would cause that? With those lights on my traction control was inhibited, as I discovered when I tried to reverse up my gravel drive on a slope!!
Now how would that make the steering lighter? Most odd.
Ha! Unless you've pumped the front tyres up way too hard to the point where the DSC can't cope.
- flimper
DSC Sensor Issue
Strange isn't it. My traction control is definitely working as I gave it some beans to test and it flickered away nicely
- enuff_zed
DSC Sensor Issue
Well that's me out of ideas I'm afraid.
What's the plan? Swap the yaw sensor as a diagnostic? Or check for other codes?
- flimper
DSC Sensor Issue
Back to TWG and see what the codes say. I imagine it will be a new DSC sensor and hope that fixes things
- enuff_zed
DSC Sensor Issue
Well that ain't gonna be cheap!
