Front anti roll bar bush size?
Murdoc
Post by Murdoc » Sun Mar 09, 2014 11:01 am
Hi,
I'm replacing the lollipop bushes (wishbone bushes), ARB drop links, tie rods (inner and outer as they have corroded together and can't be adjusted), and the ARB bushes.
I'm getting Meyle for everything but I don't know if I need the 24mm or 25mm. I have done a fair bit of searching and established the 25mm is for the M Sport suspension. My car is a '03 3.0i, I understood all 3.0i Z4s have the M Sport suspension, is this true and do I need the 25mm?
I measured the ARB with a set of digital callipers, despite the callipers having a flat battery the ARB seems to be just shy of 25mm at around 24.8mm.
Thanks.
AndyMitton
Re: Front anti roll bar bush size?
Post by AndyMitton » Sun Mar 09, 2014 11:44 am
Hi mate
Yea you need the 25mm bush. I've the same suspension as you and did this job last year. Def 25mm
http://www.realoem.com/bmw/showparts.do ... g=31&fg=10
Andy
Murdoc
Post by Murdoc » Sun Mar 09, 2014 3:25 pm
Cheers Andy.
Dean'o
Post by Dean'o » Tue May 24, 2022 11:37 am
Same question here but I got the. 2.2 z4 e85 24mm or 25mm?
