Sat Nav Retrofit Fitting Details
Onlinesrhutch
- Moderator
Re: Sat Nav Retrofit Fitting Details
The radio has no anti theft code.
hi all,
well, i ordered the following parts:
- CID / Flap monitor
- Headunit
- X3 harness
- cutting template for making whole for the montior
I already have a navigation business system, hence i have the mk3 in my car.
since i haven't obtained the coding kit to reprogramme my mk3 to the big display, will music and work anyhow?
is there any writing telling me how to modify the x3 harness to fit to my z4?
thx a lot,
nam
- Headunit
- X3 harness
thx a lot,
nam
frcac wrote:Finally got some time & peace to do it. Marked with the help of original cutting template with some diagonal references, just to check the position and symmetry. Since I got a feeling that the cutout on the template is a little too big, I opted out to make a slightly narrower cut - 6 mm according to my measurements. I was correct... I am not saying that the template supplied is oversized or not correct, I just felt comfortabler doing it this way.
... interior does look "complete" now, I think that the navigation really adds to the final image of the car.
Well, it was worth it. The last part - installation of the monitor - was quite a stresfull job with a lot of "what ifs". But I'm glad I did it
Thanks for looking and for input when needed Have a nice evening, Saso
did you fit the grey display or is it a black one? i just bought one in grey and hopefully it looks like yours...
- BettyBmw03
I had this same problem, in all the pics the black displays look grey, but when you get the display in person they are very much black. I was going to buy a used grey display off ebay and some members convinced me otherwise....bc i have black dashtop.....
Onlinesrhutch
- Moderator
you can tell if it's grey as the two buttons either side are black so completely different colour
I just received the cid today, it is in grey with black buttons- but i think it fits well to my interior - otherwise I'll respray it in black.
but still don't know to modify the x3 harness- need help!
One of the forum members (th30d0r3) customised an X3 loom, you could try sending him a PM.
Dave
Dave
- pvr
It is not so much the interior, it is the clash with the dash colour that would bother me.
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
well, for pre-facelift it's ok since most of the other parts are silver/grey too.
@bug - thx for the hint, I sent him a message an looking forward to response.
I just retrofitted the display and waiting until the other parts arrive..
Onlinesrhutch
- Moderator
looks like your head unit and vents are grey so was the best colour anyway.
What colour head unit have you sourced?
it's also in grey so I won't experience a big clash
hey guys! just bought a full system off a member down to the wiring harness, as the retrofit wireing harness is no longer available will the harness off his oem system work with my car (plug and play) i basically change everything from the amp to the speaker wires
any insight will be most helpfull i think i have it figured out but want to hear from people with some insight in this matter before i start cutting thanks guys!!!!!
- Bad_Pritt
Does anyone know if there is a way to get the turning mechanism of the monitor working without having to mount the satnav computer, gps antenna etc? I'm considering to mount the monitor but with an aftermarket satnav or a tablet computer to replace the screen... It would be great if the monitor also goes up and down. Would I need the whole loom or is there another way?
- Bad_Pritt
And yet another question
Does anyone have the dimensions (incl depth in the dash) of the standard satnav flip up/down monitor? Are the dimensions of this monitor the same as the dimensions of the X3-monitor? I have read on a few posts here that the parts look alike and that some have even received X3 parts in error when installing the standard satnav. So if the dimensions are the same... the X3 dash bin should fit the E85... hence the portable BMW Garmin system should fit the E85...?
Onlinesrhutch
- Moderator
The X3 monitor is slightly different and I would avoid as it looks wrong and the viewing angles are also slightly different.Bad_Pritt wrote:And yet another question
If you know electronics then yes you could get the motor to operate using the switches on the side independently of the vehicle.
