Battery Problems
Battery Problems
Hi all -
I have quite a problem with my 2003 2.5
I went away for a couple of weeks a few weeks ago (if that makes sense) and when I came back my Zed was completely dead - I charged it up and then it was fine for around 2 weeks (although the last two times I started it - it sounded a bit strained!) but then today it wouldn't start again.
After i jumped it and drove 20 mins it was fine and started 4-5 times in a row and put my charger on for around 30 mins and it said it was fully charged!! Therefore I think the battery and alternator are working!
In addition, I keep getting the battery warning light coming on - especially when I put something in the boot - according to the manual this is to do with the V-belt (sounds expensive!) but I can't believe that due to the fact that everytime I visit Tesco's it affects it!
Anybody got any suggestions advice/solutions
Help please - I'm beginning to wish i'd kept my A3!!!!!
2003 Z4 2.5 - Grey with Red Leather
- takedown8
Sounds like you need a new battery. Several people on this forum & others have had this issue with their Zeds. It seems like the battery gets drained pretty quickly if you don't drive it for a couple of weeks.
I think you need a new battery and battery tender.
2005 Z4 3.0i, Maldives Blue, Beige int, Black top
I had a problem with my original battery (Jan 04), took it to a mechanic who checked it and said it was done; took it to a battery outlet where they said it was OK!
A week later, didn't use the car for a day & left it in our garage; tried to start it the next day and click click click click...
Took it back to mechanic who told me again that it needed a new battery, so I bought a new heavy-duty battery & haven't looked back since.
2004 BMW Z4 2.2iSE Auto, Maldives Blue
Thanks for the replies.
Well, I took it to my local Kwik Fit to check the battery today and it read about 12.5 volts and over 14 when the engine was running which looks pretty healthy to me....
It ran completely flat when I left it for 2 weeks and I wander whether the battery power it ok but capacity is not??
Also, I recently removed the in car phone from it but left the power cable in so this could be drawing on it and draining it but I can't believe it would use that much power
What do you think?
What do you think?
It might seem OK if checked just after you've driven it to the mechanic and it's charged a bit; however, if it's not driven for a while (say left at airport) and doesn't hold an adequate charge... it's bu****ed! A new heavy duty battery only costs about £60 supplied & fitted if you know where to go; well worth it presuming that's the problem.Z4 Forum AMW wrote:Thanks for the replies.
What do you think?
A general thought for the forum: I always have the engine running when operating the soft-top; does anyone activate the hood without the engine running (potentially a huge cumulative drain on the battery)?
Well, I went to my local dealers and they wanted around £90 + VAT just to check the thing and I would of let them had it not been for the fcat that no courtesy car was available for about 3 weeks!
Then I was passing my local ATS and thought i'd get a second opinion - they attached it to a proper Bosch testing thing as opposed to Kwik Fits Voltmeter and it came back unserviceable so I got a new one for about £75 fitted and so far so good!
I'm sure you'll hear again if it doesn't work but thanks for all your help!
- takedown8
The majority of the time, I put the top up and down without the engine running. I can't see that draining the battery to the point where I can't start the car. That would be pretty ridiculous if that were possible, IMO.Tim wrote:A general thought for the forum: I always have the engine running when operating the soft-top; does anyone activate the hood without the engine running (potentially a huge cumulative drain on the battery)?
- sp3ctre
- Site Admin
I never put it up with the engine running... I have the remote roof module so roof goes down when I'm approaching the car, and up when I'm walking away.... been doing that for 8 months now and never had an issue.takedown8 wrote: The majority of the time, I put the top up and down without the engine running. I can't see that draining the battery to the point where I can't start the car. That would be pretty ridiculous if that were possible, IMO.
- JBZ4
- Albertoxx
Re: Battery Problems
I had the same problem with my Alpina.
I purchased a new battery...same problem.
I went to the stealer that replaced alternator...( fortunately everything paid by insurance) ...same problem.
Now I purchased a charger... same problem... but no more stealer
(it only happens when I'm on vacation or a job travel--> when I leave my Z for a couple of weeks in the garage. Now I know and when it happens I plug the charger and leave the battery under tension)
My wife is Head of R&D and Electronics at Ferrari and she says that they have often the same problem ... so don't cry, we paid much less!
Alpina Roadster S #89
Albertoxx wrote:I had the same problem with my Alpina.
Can I have your Wife?
I don't want a Ferrari, just her brain......
Drives 2008 Z4MC (His) & 2003 Z4 Roadster (Her's)
- Rick Hunter
