Z4 roof only closing half way - (NOT THE PUMP!)
- bigwinn
Sorry lads been off line
Dr T pm me Iโll send you my mobile
Itโs the braided cover- strip it away
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
bigwinn, .... Almost there, found the culprit....
- enuff_zed
Excellent work. Think I'd be resplicing the lot looking at that!
bigwinn, enuff_zed, thanks guys! We're back with a working power hood!
I've respliced them all as you suggested enuff_zed, and asides from one of the side torx screws, everything's back in place where it should be
Thanks again for your help gents - much appreciated
- bigwinn
Yes chief!!!
Love it when a fix gives so much satisfaction
Good job
Good job
EWS Delete PM me
EWS Delete PM me
bigwinn, definitely mate ... It's made my weekend
- bigwinn
im off to have a beer in your honour
EWS Delete PM me
EWS Delete PM me
bigwinn, bloody good idea, I'll join you!
- enuff_zed
Well done indeed. The glow of satisfaction when you fix something yourself!
enuff_zed, absolutely! Thanks again for your help! Enjoy the rest of your weekend
Hello all,
Brand new to the forum and Z4 ownership. Sorry to revive an old thread but I had this problem with my new Z4 and this is the thread that came up in my Google search and helped me fix the problem. Hence, I thought I'd add some additional info to hopefully help out anyone in the future.
To remove the headliner and access the wiring loom firstly move the roof to the following position: Remove torx screw on each side of the roof as shown (1 each side) Remove four torx screws along front of roof headliner (2 each side of the latches) Remove access panel at the front of the roof (just pull on it) and remove one torx screw With a small amount of force the plastic trim will now come off the roof and bring the fabric of the roof liner with it.
You will now be able to see the wiring loom along the passenger side and front of the roof leading to the motor at the front of the roof.
Feel along the wiring loom until you find a "fat" bit where the wires are bent. This was in the front left corner of the roof for me. Alternatively carefully cut open the length of the outer sheath until you find the problem. Cut and solder in replacement wiring to fix the breaks/bends. Cover in shrink wrap/electrical tape as appropriate. Wrap everthing in sheath or electrical tape to keep it all together. Put everything back together in reverse order to the above!
- smorris_12
Nice set of pictures! I'm sure we'll all face this at some point!
Scott
Where are we going and why am I in this handbasket?
2006 Z4 2.5si Silbergrau und rot
Scott
- N4LLY
THANK YOU to everyone whoโs contributed to this thread over the last ten years! Problem solved on 2003 3.0 Z4 with roof stopping part way up. I found the broken wire about 18 inches from the latching motor once I cut open the wire shielding. Everything works now as expected.
