Tyre Pressures for CSLs in Vreds
jimmybell
With the purchase of a nice pressure gauge for my tyres (amazon link), Any idea what pressures i should be running?
I've got replica CSLs, wrapped in Vredestein Ultrac Sessantas
Front: 235/35/R19
Rear: 265/30/R19
Currently i think i've (scarily/weirdly) got:
Front offside: 25psi
Front nearside:31psi
Rear offside: 32psi
Rear nearside: 27psi
I'm aware the 25/27 are wayyyyy out from hat they should be - and i've no idea why they're that low .. but the question is - what should i be setting them all to?
Front 2.0 bar (29psi) Rear 2.2 bar (32psi).
However, a tyre company I consulted said even if it was 30psi all round it would be OK.
cool - lines up with what i was thinking, ill probably do as you say. due some new rears soon but hopefully the pressures being this far out hasnt caused any uneven wear.
jimmybell said:
...... but hopefully the pressures being this far out hasnt caused any uneven wear.
That was a particular question I raised with the tyre company and their view was that tyres will quickly wear out when drivers take corners and roundabouts at excessive speeds rather than wear caused as a result of tyres being a pound or two over/under manufacturer's recommended pressures.
