Puncture solution
- monkadill
Puncture solution
Once you have ditched the run flats what are the best options for punctures?
- Ste
Re: Puncture solution
Good breakdown cover
Some people opt for a spacesaver tyre in the boot too.
You can of course get a can of tyre gunk and a compressor (or some of the tyreweld stuff you don't even need one) which will help you limp home, but 9/10 that ruins the tyre so can't be repaired. If I got a puncture near my house my first point of call would be a local tyre garage to come and take the wheel off there and then, or the AA if outside normal working hours.
- monkadill
I already have the breakdown cover but if i am in the middle of the Lake district i need the option to get out of the hills so a space saver seems the way.Any recommendations?
- monkadill
Just stumbled on this thread about the topic..
Thanks for the response
http://www.z4-forum.com/forum/viewtopic.php?f=2&t=19888
- Ste
In that instant, feel free to give me a ringmonkadill wrote:if i am in the middle of the Lake district
there is a gunk you can put in the tire when you dont have a puncture - and it seals any holes you get - i wonder if it is worth considering
[img][/]2007 2.5 si, dension, new sub woofers and amp, cup holders,mods on the list, sound gen, exhaust bypass, lsd, cruise retrofit.....
I have a DIY tyre puncture repair kit, the rubber worm type. Works perfect, no gunk and Takes about 5 mins to repair and re inflate.
- Silverfox
mr nurburgring wrote:I have a DIY tyre puncture repair kit, the rubber worm type. Works perfect, no gunk and Takes about 5 mins to repair and re inflate.
sounds good, do you have a link for it?
2.0i SE, black leather, 108's, Alu stubby, Stainless Steel tail pipe
http://www.ebay.co.uk/itm/BRAND-NEW-TUB ... 20c03594c6
That's a cheap on from India, I got mine in the uk, 10 rubber strips, 5 small and 5 large, they work great, fixed a mates tyre a few months ago and it's not leaked. It's a permanent repair.
Never need go to a tyre shop again.
- AlanJ
Search and search again.....
I thought the worm/plug/mushroom type repair kits were not meant to be used as a permanent repair on tyres with a W, Y, or Z rating. I thought the only 'legal' permanent repair on a W/Y/Z tyre had to be hot galvanized?mr nurburgring wrote:I have a DIY tyre puncture repair kit, the rubber worm type. Works perfect, no gunk and Takes about 5 mins to repair and re inflate.
Although anything is better than nothing in an emergency - just don't plan on doing a trackday or 1000 miles on it
- aquazi
breakdown cover, or if not travelling far gunk, and compressor.
Although if i were to ever do a drive to europe i would always get a space saver and jack.
I know they say not a permanent repair bit I can't see why not.
A mate used on on his r1 did a trip round Europe and a track day at monza, I think ill be ok going to work!
- It's a fair cop...
Picked up a nail at a track day a while back and successfully effected a repair with a mushroom headed wood screw. Finished the last session on it and made it home too.
...but society is to blame, guv
z4 18i m sport, auto, mineral white, black kansas, 19" style 326, hawaiian tropic in the glovebox
evoque 2.2 sd4 dynamic, manual, firenze red, ebony, 19" style 5, pano roof, wurthers originals in the glovebox
You've got bigger balls than me then, as I'd have driven home carefully after affecting a 'temporary' repair, and wouldn't have even attempted to do the last session on a known damaged tyre.It's a fair cop... wrote:Picked up a nail at a track day a while back and successfully effected a repair with a mushroom headed wood screw. Finished the last session on it and made it home too.
