Removing the behind-seat speakers
- SynapticFire
My passenger-side rear speaker is proper knackered, so I've got another one off fleaBay for £16 or so - just need to fit it!
I don't have the fancy system, just the standard 6-speaker setup, so I've got the small circular speakers. Does the grille just pull off or do I have to go in from behind? ( )
I read the instructions on fitting an Intravee and getting to the DSP speakers which looks like a right ballache so I'm hoping the standard ones will be a lot simpler!
Buying a used BMW? Whatever you do, don't use HS Cars Ltd. Here's why!
- Wondermike
- Moderator
Re: Removing the behind-seat speakers
They fix from the inside of the cabin so presumably the grilles will prise off so you can get to the screws.
- SynapticFire
Sweet. Just got a set of interior removal tools so I can give that a try tonight or tomorrow
- oli445
Don't think its that easy. If you are talking about the 4" mids behind your head I thnk you have to take the centre console out and remove all the plastics on the bulkhead!
- aquazi
Yep the circular mids are a pita to remove
- Wondermike
- Moderator
Ooops, sorry for the bad advice
Wonder why they make it such a pain
- SynapticFire
Aaargh no really?? I had a look at the Intravee install document and it talked about taking everything out to get to the DSP-system speakers (you have to reach in from behind and push the grilles out) but it said nothing about the 4" ones :-/
- SynapticFire
Balls!! Found another forum that says the same thing. Looks like they're screwed directly to the bulkhead
That's going to be a friggin' nightmare.
- SynapticFire
Well, today's the day that I either fit a new speaker or break half of my new car >.<
- oli445
Good luck and take plenty of pics to share!SynapticFire wrote:Well, today's the day that I either fit a new speaker or break half of my new car >.<
- SynapticFire
I couldn't get the centre tray out!
I pulled it when it was fully open, it wouldn't budge. I found pvr's thread and it looked like he had it at a higher angle ... That wouldn't work either
I took the little screws out of these bits, and again nothing would budge :-/
- oli445
I had the same problem, messed around for nearly 2 hours. Then gave it a proper PULL wiggling it about and it came off. I thought I had broke it but I hadn't, all went back together perfectly
- ranski
Just make sure you align the angle and as above give it a good pull
Z4 3.0 / Mods done... too many to mention
- SynapticFire
What. A. Bloody. Nightmare.
I went back out today, and the centre tray popped right out!
'Hard part done', thought I.
HA! How wrong I was. Took my housemate and I about two and a half hours, but we got it all apart, put the new speaker in, and got it all back together again. The only casualty was a slight rip ( ) inside the roof when it was going up and down as we tried to get the plastic bit behind the roll hoop back on. It's not noticeable but I worry what it means for the weather-proofing :-/
Either way, I now have a functioning speaker
- SynapticFire
I utterly failed in taking pictures for a how-to. My advice would be 'take it to a professional'
However, here's what things look like with all the gubbins removed. Why BMW had to make it this hard to get to a teeny little speaker I will never know!
