Replacing run flats with normal tyres..
Hi guys,
I've tried searching for this topic but not really found any definiative answers...
Can normal tyres be fitted to wheels that have run flats on...?
Only i need to replace my rears soon and i wouldn't mind a slighty comfier ride, but i realise that a spare wheel would then be needed.
- Jembo
Re: Replacing run flats with normal tyres..
I thought replacing all 4 might be the answer, the fronts are brand new and the rears have a couple of thousand left in them. It's a tough call to make as i'm in no position to replace all 4...and then there's selling the run flats too.
Slightly off topic, but i'm looking to take off my door trim panels, in the quest of stopping the glass rattling...How difficult is removing the door cards? And what tools does this involve?
- Jembo
The bottom bits are easy, getting the top bits off are a nightmare.
I put dampening material to stop them being tinny & ended up wedging it open from underneath coz I just couldn't get them off. Don't try taking them off without the instructions as u need to be very careful with the airbags
Best of luck, am sure someone on fleabay will take yr RFT's off u
- Citation 650
Great, thanks for the link and advise, think it might be worth getting a haynes manual in that case...will always come in handy!
Back to the tyres situation....i think i read a post on here somewhere that some was running run flats and the front or rear and the normals at the opposite end...? Not sure which way round this was but they said it worked out quite well
I've got two brand new Bridgestone Potenza S001 on the front and its the rears that need to be replaced...
If anyone has any experience with this sorta dilema it would be great to hear from you!
Many thanks!
Many thanks!
- tom_ekn
I'm in the same position as you. Rears will need changing soon so going to go over to normal tires. From what I have read its best to do all four at the same time
2008 Z4 3.0si Coupe
Generally believed to be the correct procedure, RFT and normal tyres have very different characteristics .tom_ekn wrote:I'm in the same position as you. Rears will need changing soon so going to go over to normal tires. From what I have read its best to do all four at the same time
Always worth considering the consequences of having an accident and the investigators finding tyres of different construction
and how that might be viewed regardless of those saying they do mix and the car handles "fine"
2007 Z4 3.0 si Sport Auto Monaco Blue Roadster / 2013 X1 2.5d Auto M Sport White
1st BMW a 2002 when they were current ..! and wife has a 2014 Mini Cooper auto
All BMW family
All BMW family
- Bing
I am sure this is answered elsewhere, but I may as well just ask - do you tell your insurers when you change to non-RFTs ?
Current... Silver Grey ///M Roadster, non-flimper spec, Imola Red nappa, permanent ear-to-ear grin
IIRC Insurers all seem to have different views ,some say it is a change to OEM spec and is also not supported by the ManufacturerBing wrote:I am sure this is answered elsewhere, but I may as well just ask - do you tell your insurers when you change to non-RFTs ?
Other seem not to be too worried .
However old issue is that if your Insurer is not of the it's OK school then in any claim situation you could find you are uninsured..................
All BMW family
All BMW family
- Bing
I think direct line may be ok - when I changed to winter wheels with non-RFTs they didn't bat an eyelid. I will ask them before spending £500 though
I ran a 3 series with RFT on front and normal tyres on the rear with no problems. As long as you are no driving it like you stole it you will have no problems. You can tell in the ride over bumps etc but not when cornering, accelerating or braking.
I am in the tyre business and have found the Kuhmo to be an extremely good tyre far better than a Dunlop which I currently have on the rear of my M Coupe. If you want a dirt cheap price drop me a PM and I will have a look whats about, there is always 1 manfacturer got an offer on.
Z4MCOUPE 2007 Carbon Black
- srhutch
- Moderator
Non runflats are half the price of rfts if you go for something like Falken 452's which are a forum fav.
I changed all 4 then sold my fronts with 5mm for £130 to a forum member.
- WizzEssex
I'm insured through the AA- they were not at all interested in my new NRF tyres as long as I had the right speed rating tyres.
This is the tire that I would have purchased, if I didn't decide to keep the Potenza's. I will replace the run flat tires when they are worn, and will replace them with this tire.
http://www.treaddepot.com/review/zrs3a.html
