Good tipkis wrote:Theres a well reputed Z4 breaker on ebay selling part 6965147 which is the superseded version of my ECU, if you're any further on diagnostics then possibly worth hitting it up? Don't come up very often and when they do they're extortionate. Maybe worth lifting your centre console out PARTIALLY just to read the part number? Then you know...
Airbag Control Module
- Chris_D
- kis
That's if your issue is you're module... It could be the passenger seat mat sensor, or even one of the two pillar modules?kis wrote:Theres a well reputed Z4 breaker on ebay selling part 6965147 which is the superseded version of my ECU, if you're any further on diagnostics then possibly worth hitting it up? Don't come up very often and when they do they're extortionate. Maybe worth lifting your centre console out PARTIALLY just to read the part number? Then you know...
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- kis
this oneChris_D wrote:Good tipkis wrote:Theres a well reputed Z4 breaker on ebay selling part 6965147 which is the superseded version of my ECU, if you're any further on diagnostics then possibly worth hitting it up? Don't come up very often and when they do they're extortionate. Maybe worth lifting your centre console out PARTIALLY just to read the part number? Then you know...
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- Chris_D
Nice one thx.kis wrote:this oneChris_D wrote:Good tipkis wrote:Theres a well reputed Z4 breaker on ebay selling part 6965147 which is the superseded version of my ECU, if you're any further on diagnostics then possibly worth hitting it up? Don't come up very often and when they do they're extortionate. Maybe worth lifting your centre console out PARTIALLY just to read the part number? Then you know...
Carly has thrown up multiple airbag codes making me suspect its the module so i'll be digging deeper to clarify...
- kis
My fault code is 93DB which translates to a module fault...
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Hey guys,
if you need some help, by replacing and reprogramming some Sim85 or SBSL an SBSR let me know,it.
I replaced and reprogrammed many faulty modules in germany, its not an easys job, but it works.
regards
regards
- kis
Right so I managed to sort my airbag. The dash looks a bit strange without the red airbag light on!
My conclusion. If you've got a problem check it's not something straightforward like the seat occupancy sensor or seat belt tensioner. Those will be quick easy fixes, well relatively speaking. So get your hands on a decent diagnostic device and see whats what for you. It'll pay to do good diagnostics first. Either by yourself or paying someone with good kit to check for you. It'll save you muddling around looking to fix things which aren't the problem.
If things point to the airbag ECU module then try resetting the car and drying the module out. A few people now have had issues where the module has got wet or a bad connection. If you disconnect the battery (20mins) and then remove the module (leave to dry and maybe spray with WD40) then try reconnecting. Obviously you'll need to run diagnostic software again and then try clearing all airbag codes.
Finally if all else fails you've probably got a bad module. I took off the centre console to take a photo of my module. With this you can find out which part numbers are interchangeable and look out for a used one on ebay. Once you've got this you can plug it into the car but it won't work without programming the module. You'll need to change the VIN or chassis number on the module to suit your car. This'll need to be done with specialist coding software. You also need to take care you don't mess anything up if you do this yourself as it could brick your module - not trusting myself I paid someone to do it! If you're a perfectionist you can even code the mileage (of the module) to that of your car as well.
If you do a full diagnostic reset now you'll be airbag light free!
Hope this helps someone out and if you need more info, etc. feel free to PM me
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- paullyjay
I know I'm resurrecting an old thread here, but I am having the same problem and, in doing my own research, I came across the following list of part numbers for the control units (from realoem) and whether they are interchangeable or not... Perhaps this will be useful to others!kis wrote: ↑Thu Oct 27, 2016 11:18 am Still on the hunt mate. Most people on ebay/breakers asking for £150 (I only ever found two!!). I'm looking for slightly less - I'm a bargain hunter what can I say! Come on ebay every now and then so keeping my eye on that, and any "new" Zed's that appear online for breaking.
Also to note for your own situation, part numbers are quite specific so you can't just pick up any module. I ripped apart the car to get my hands on my part number which is 6935920. I did my own research and then I went to BM and that part has been superseded by 6965147. Which is what I got too. So basically I'm after either one of the two part numbers mentioned above.
My MOT still isn't for a while so looking hopeful. Otherwise £150 looks a dam lot better than £400+ which is what BM want for a brand new one. If I can actually get my hands on this blasted part, my indie says he can flash it with my serial numbers, etc so that the car can talk to the module. That's what he says ... and thats the plan!
Good luck with your own airbag light!
65776965147
Control unit airbag
Superseded by:
65776933933 (09/01/2003 — 09/12/2003) , nonexchangeable retrospectively
65776938264 (10/01/2003 — 08/27/2009) , Exchangeable retrospectively
65776939811 (04/01/2004 — 08/27/2009) , Exchangeable retrospectively
65776962767 (07/11/2005 — ) , Exchangeable retrospectively
Supersedes:
65776935920 (03/01/2003 — 02/14/2005) , Exchangeable retrospectively
65776928570 (11/25/2002 — 07/30/2003) , Exchangeable retrospectively
65776928519 (09/02/2002 — 07/01/2002) , Exchangeable retrospectively
65776924885 (09/02/2002 — 05/22/2002) , Exchangeable retrospectively
65776926781 (09/02/2002 — 04/23/2002) , Exchangeable retrospectively
65776924603 (09/02/2002 — 03/18/2002)
- enuff_zed
paullyjay, speak to bigwinn.
He has the one you are looking for.
- bigwinn
I do!
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
I'm also resurrecting this old thread again, just 6 months later.
I have the same problem. Airbag control unit is dead. My European Z4 E85 2.5i BT31 was manufactured in Feb/March 2003, and the faulty control unit is 65776928570. I found one 65776928570 for sale in Belarus, but I don't think it's possible to buy it from there.
According to RealOEM.com, exactly the same control units that paullyjay posted above should be compatible with my Z4:
https://www.realoem.com/bmw/enUS/partxr ... series=E85
However, I am a bit sceptical if the units 65776938264, 65776939811 and 65776962767 would actually work. The name of those units changed from "Airbag control unit" to "Safety information module". I also suspect that the information on the page below might mean that those modules only work with Z4's produced after 10/2003:
https://bmwteilekatalog24.info/BMW/P/E8 ... 5776928570
Much now depends on whether 65776962767 is actually compatible with my Z4. Right now one is for sale on eBay.
Any advice on whether 65776962767 would actually work with a Z4 manufactured in 03/2003?
If it doesn't, any hints on acquiring a working and compatible airbag control unit would be highly appreciated. Without it, my Z4 won't pass the next inspection next spring and is doomed for the scrapyard.
