not sure how to check this though:Stuart Truman wrote:It could be as simple as a sensor. Is the car misbehaving in any way? Running rough etc? Nope
No sign of oil contamination in the coolant? Nope
No sign of mayo in the oil filler cap? Nope
What's the temp gauge doing? (although iirc that's oil temp) Stable in normal temperature
by sensor, do you mean the little stick floating when removing the cap? or do you mean something electronic? ok I'll go look if I see any wire, just that I don't know where it could beBefore anything else, see if the wire has come off the sensor. Although I don't know the zed specifically, a lot of these work by grounding the line when they overheat, so if the wire comes off and is flapping around it will short and the light will come on. I'd expect that to cause flickering on and off though.
I'll check and come back, thanks again!
