Roof Closing then windows opening problem
- MikeS
I have started having a minor intermittent problem with the roof closing sequence on the car. Sometimes when I close the roof and the windows close one or both of them opens again by about 8 inches. (Yes I do wait for the light to come on and take my finger off of the button immediately.) This does not happen all of the time and sometimes it is just the driver's side or the passenger's side that is affected. The dealer took the car in for a couple of days and tried to 'adjust' the windows but the problem remains. Now they are contacting BMW for advice. Anyone else had this problem?
SDRIVE35i Space Grey, 7 speed DCT, adaptive M suspension, V Spoke 19" wheels, Nav pro with HDD, Comfort access and most of the other toys!
- jamiecarpenter
Re: Roof Closing then windows opening problem
Yep I've had this happen quite a few times. Found that it happens if the battery has been disconected. I tend to then reset them by holding them down for 10 seconds to the bottom, then hold them to the top for a further 10 seconds. If this doesn't work try again.
Silver Grey 3.0 si 06. Retrofitted sat nav, Cruise Control, Intravee, Door Cards and Heated Seats.
- Z4 Beemer
Yes, I get this - sometimes the passenger window, sometimes the drivers and tonight it was actually both that went back down. I think its just the sensitivity of the anti-trap, maybe since the battery has been loaded more when the roof is closing.
To be honest it doesn't bother me and I just hit the roof close button again and they go back up! I wonder if it makes a difference if you use the "master" close window button on the door to put them up after the roof operation has finished?
Current: 2016 Audi S3 :: Navarra Blue
Gone: 2009 Z4 sDrive 23i :: Deep Sea Blue
Gone: 2004 Z4 2.2i SE :: Maldives Blue
- AlanJ
Windows reset is in order I think.......
1. Turn on the ignition
2. Depress the individual window button until the window is open, then keep it pressed for 5 seconds longer.
3. Depress the window button until it is closed, then release.
4. This should reset the memory on the window.
Same procedure for both windows
- ksher
I only use the roof close button to close the roof, then use "all windows" button to close all 4 windows.
Current BMW: 640d Gran Coupe M Sport (F06), 118d SE (F20).
Previous BMW: Z4 sDrive23i M Sport (E89), 318i Sport (F30), 120d SE (F20), Z4 2.5i Sport Roadster (E85), 523i Sport (E60), 323Ci (E46), 523i SE (E39), 318i (E36).
Mine does it too, with the engine running and with it off. Not a big problem - I guess more of a feature.
Do you have to keep pulling on the all window button, or is it one touch?ksher wrote:I only use the roof close button to close the roof, then use "all windows" button to close all 4 windows.
On mine one touch only works when lowering them.
John
- AlanJ
4 windows....?ksher wrote:....... to close all 4 windows.
- EdP
Yes, the E89 has 4 windows.AlanJ wrote:4 windows....?ksher wrote:....... to close all 4 windows.
- Z4 Beemer
That's right one touch for lowering all 4 and you need to hold it to pull them all up.JohnT wrote: Do you have to keep pulling on the all window button, or is it one touch?
John
- Breaker
- AlanJ
Oh yes - sorry thought yours was a proper Zed - ROADSTEREdP wrote: Yes, the E89 has 4 windows.
- EdP
I have no idea. What is a proper roadster? The fewer windows the better?AlanJ wrote:Oh yes - sorry thought yours was a proper Zed - ROADSTEREdP wrote: Yes, the E89 has 4 windows.
- ksher
E92 coupe has 4 seats, but you can only open/close 2 front windows. E89 roadster has 2 seats, but it has 4 windows. Does anyone lower the rear windows when driving? I don't.AlanJ wrote:Oh yes - sorry thought yours was a proper Zed - ROADSTEREdP wrote: Yes, the E89 has 4 windows.
Mike: Can you only operate the front windows in your SLK (although it also has 4 windows)?
- MikeS
The battery has not been disconnected from the car and the windows worked fine until a few weeks ago. Just tried the 'window reset' idea or though if this really does anything I would have to wonder how. That said I opened and closed the roof twice all all worked OK!!! Will wait to see what happens next week.
