Throttle adaption reset
sp3ctre
Site Admin
Site Admin
Post by sp3ctre » Mon Jun 25, 2007 4:16 pm
If you have different people driving your car, or have been doing a lot of town driving, this can help to reset the throttle responsiveness back to factory defaults.
Turn ignition off
Turn key to "on" position
Wait 15 seconds
Turn ignition off
Wait another 15 seconds
Start the car.... you should find the responsiveness has been reset.
Flycaster
Re: Throttle adaption reset
Post by Flycaster » Sat Sep 22, 2007 9:50 pm
Hey, sp3ctre, I've seen this several times before on other BMW forums. The wait period has always been 10 seconds. I'm no expert here, so I'll leave the 10 vs 15 second issue up to you.
2002 TiSil 325i, Step, SP; 2005 Merlot/Tan Z4, 2.5i, Step
Curtis
Post by Curtis » Sat Sep 22, 2007 11:48 pm
The other way is to disconnect the battery for 20 minutes. Once reconnected the computer is forced to reboot. You have to reset your clock, date and windows though.
harrissot
Post by harrissot » Tue Sep 22, 2009 12:08 am
guys as a noobie at the forum and also with my z4 i would like to know what exactly does this reset does...!
first of all does it affects consumption? second is it harmful to do it many times? once a month for example? and also does it affects the clutch? (i am saying it because when i did it i felt that changing gear became more ''hard''.
Smokin
Post by Smokin » Tue Sep 22, 2009 1:18 pm
Doesn't do any damage-you're merely resetting the adaptive throttle response. Your car "learns" how you drive and adapts. If you've done a lot of in-town driving, the response gets set to less responsive (you're only giving it a little gas and you're doing a lot of idling). The reset only affects throttle response, but since it's almost always quicker after reset, you have be ready for it shifting gears. If you're always driving in the same place, though, it's not really worth it. Those of us who do a lot of "mixed" driving, the in-town stuff can bog them down.
2007 3.0si coupe, sapphire black, saddle brown extended leather, heated M seats, premium package, sport package, Carver, light poplar wood trim, xenon, headlight washers, 6 spd. Member BMWCCA, ZSCCA, Homecoming 08 Pirate.
RobM77
Post by RobM77 » Thu Oct 29, 2009 5:18 pm
I've just bought a Z4 Coupé and find this very interesting; I'll try it tonight! However, someone above mentions resetting windows... What is there on the windows that I can set?
sp3ctre
Site Admin
Site Admin
Post by sp3ctre » Thu Oct 29, 2009 5:21 pm
Sometimes the windows lose their one-touch up/down function. Resetting the windows fixes this. It is different to the throttle body reset though, the windows don't alter the throttle :D
sk93
Post by sk93 » Mon Nov 02, 2009 4:42 pm
sp3ctre wrote:the windows don't alter the throttle :D
oh that depends entirely... I've definately found that the throttle is usually more open if the windows are DOWN in a tunnel, rather than up...
:zzzz:
Darkman
Post by Darkman » Mon Apr 05, 2010 8:55 pm
Beware disconnecting the battery, it can also deactivate other features on the central body electrics as I have found out. No aircon fan speed only works on slow and the heated rear screen is deactivated. This was due to letting the battery run down over the winter in the garage. Its going in next week to be reset at the dealer.... and yes I have tried disconnecting the battery for 20 mins and its still the same. :headbang:
The Zed will remain on a trickle charge once its rectified, not paying twice .....
The chains of habit are too weak to be felt until they are too strong to be broken.
chopper
Post by chopper » Sat Jan 15, 2011 8:15 pm
Hey guys... Does this throttle reset work the same on the new E89 ?????
Z4 2.3 Sdrive Msport - Melbourne red, pure white design, 19" rims
Dav the wheel nut
Post by Dav the wheel nut » Sat Jan 15, 2011 8:44 pm
Does disconnecting the battery effect the radio?
srhutch
Moderator
Moderator
Post by srhutch » Sat Jan 15, 2011 8:57 pm
Dav the wheel nut wrote:Does disconnecting the battery effect the radio?
Slightly off topic :poke:
but no to answer your question
sp3ctre
Site Admin
Site Admin
Post by sp3ctre » Sat Jan 15, 2011 9:00 pm
I assume disconnecting the battery turns off the radio... either that or you have a very special radio :poke: ;)
Mafoo
Post by Mafoo » Sun Jan 16, 2011 6:45 pm
Slightly off topic again........
I performed this for the first time today. The majority of my driving is stop start. I'm amazed at the difference in resetting.
Moreover, upon resetting, the power of my heater seems to have doubled. Would this slso be expected?
Sent from my GT-P1000 using Tapatalk
Z4 3.0i SE - gone but not forgotten
Need a Forum approved Specialist Independant Garage? viewtopic.php?f=4&t=38928
ferrelscent
Post by ferrelscent » Thu Jan 20, 2011 11:11 pm
Am I right in saying that this will only make a difference when in non-sport mode ?
Who is online
Users browsing this forum: No registered users and 0 guests
