Post 04 cruise control retrofit N52
Re: Post 04 cruise control retrofit N52
Spot on, thanks. Fixed - easy when you know how!
2.5si, 2007. Black, individual black/white interior. Sat Nav, bluetooth, iphone, heated seats, proper aerial - not a poxy stubby! GapTech, retrofit cruise.
- dan425
Glad it worked. Happy to help!revesby37 wrote:Spot on, thanks. Fixed - easy when you know how!
Sent from my GT-I9100 using Tapatalk 2
E85 Z4, 3.0i, 2005.
draggin up an old thread but i dont suppose anyone has the photos from the orignal how to guide? seem to have been removed from forum maybe as such as old post. looking to do this on the weekend and cant find anything on youtube and the photos would be a massive help
thanks in advance
thanks in advance
- Guiseley
Photo's on page 1 of this thread seem to work OK for me (are they the ones you can't see?).welsh1 wrote:draggin up an old thread but i dont suppose anyone has the photos from the orignal how to guide? seem to have been removed from forum maybe as such as old post. looking to do this on the weekend and cant find anything on youtube and the photos would be a massive help
thanks in advance
Blue Z4C now long gone, as is it's replacement, and the Red Zed's gone too.. now piloting a rather tasty Carmine flat6
thats the ones, maybe its the work computer. will try at home
thanks
thanks
- aquazi
Works for me too... Maybe your work filter blocked the host... My work filters photobucket/ flicker.
anyone fitted this on an Auto? have an 2007 3.0i auto, assuming it would work just like the manual and same connections etc ?!
thanks
thanks
- Guiseley
Would assume auto is same, but fitted mine to a manual 3.0 si.
- Bing
Jan_Tekin and I did this on our cars at the weekend - thanks to all who contributed, between this guide and the BMW instructions it was all pretty straightforward if just a little fiddly at times
Jan's is a manual, mine is an auto - no difference in installation. Oh, and make sure you ask Sopers to print and send the BMW instructions with the kit, or do a search on here as I think they are posted somewhere.
Couple of other things (may have been covered, may not...) :
1. It is much easier to get to the loom and cable ties behind the light control unit if you take the air vent out too. The loom is cable tied to the dash so doesn't have much slack - taking the air vent out helps get at the block on the back of the light unit to detach it.
2. To detach the block, use a wee screw driver to press down the catch, then get your fingers in and pull the white clip forward and down. Needs quite a bit of force, you'll know what I mean when you do it.
3. There's a lot of talk on here about what pin to use in the engine side connection. This may be because the BMW instructions are ambiguous. There are directions for the M54/N52 built up to 09/06, and others for N52 built after 09/06. Both route the blue cable to different pins. My car was built 02/06 and Jan's is an 07 - BOTH our cars used pin 39. Some of the electrical box internals on our cars are different, but the cruise control works in both. Perhaps a typo in the BMW instructions, as the M54 was not built in 2006 as far as I know...
4. Finally, the instructions say you need to use the 'repair kit' to extend the blue cruise control loom wire. We could not work out why as the connecters on the loom and the repair section were identical so we did not do this, plugged it straight in and works fine. You may well have to use the repair wire for the M54 engine, but I can't confirm this.
Hope this helps
Hope this helps
Current... Silver Grey ///M Roadster, non-flimper spec, Imola Red nappa, permanent ear-to-ear grin
- aquazi
Damn i should have joined you guysBing wrote:Jan_Tekin and I did this on our cars at the weekend - thanks to all who contributed, between this guide and the BMW instructions it was all pretty straightforward if just a little fiddly at times![]()
Hope this helps
- Bing
Sorry aquazi... If I'd known you'd have gotten an invite
- MrPT
Ordered a cruise control stalk + harness from Sopers. Excellent service from them as usual, but the kit appears to have 4 x socket contacts and no plugs:
I'm buggered, right?
2008 Z4MC: SG/Imola | +OEM CSLs | +KWv3 | +TMS RTABLs | +VT mounts | +Eventuri | +OEM strut brace | +DB9 front BBK | +cruise - probably looks a bit like your one
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- Z4 TEX
What you think you are missing?
- MrPT
2 x D. I've got 4 x E.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- Taz
how much is the kit these days?
