Driver Side Window Loose
This is the 2nd time the driver side window has become loose. By this, by grabbing the rear of the driver side window, you can move the window up and down. When the window moves up and down, you get a ticking sound inside the door like the mechanism is missing but the window will go down and up. The last time ig ot this repaired, it was just the lining and tightening of the window but this was only 1 yr ago. Anyone else had this problem?
Re: Driver Side Window Loose
i had the passenger window get knocked off the track when my daughter closed the door too hard. dealer popped it back in place - no charge. (sometime in '05)
This problem is very common for BMWs in general, our E46 3 series and X5 both had all window clips break.
Had it also for both windows of my Z4.
Check for leaks after they change the clips since I pretty much guarantee you your car will leak after(water from window channel to your inner door panel then down to your carpet.
- Rick Hunter
Welcome to the forum, melbs. I remember you from the "other" forum. Hope you're no longer experiencing any leaks?
'07 Imola Red Coupé
- sp3ctre
- Site Admin
mmm, mine is the same.... rattles like mad when the door is closed hard, and I can move it with my hand v.easily. Car is well out of warranty so I guess I'm on borrowed time until it breaks properly.
Thanks for the welcome rick hunter, did you also go by that handle before? yup its still me melbs from z4um. actually the z4 still leaksRick Hunter wrote:Welcome to the forum, melbs. I remember you from the "other" forum. Hope you're no longer experiencing any leaks?
yup, but don't let it break properly or else your regulator might prematurely break with itsp3ctre wrote:mmm, mine is the same.... rattles like mad when the door is closed hard, and I can move it with my hand v.easily. Car is well out of warranty so I guess I'm on borrowed time until it breaks properly.
- CAN217
i wonder if that's what happened to my driver's side window. i had my Z4MC for 1 week and when I closed my rear hatch, the driver's side window exploded. Dealership had no idea what happened; but, was very helpful in taking care of it.
I had this on my 2.5. The window is clamped in place with a bolt. When that works loose the window can move up/down a centimetre or so. Its easyish to fix... Remove or lift away the inner door panel; screws under door pull/ handle, lock lever and under air bag logo. The torx bolt can be accessed through a hole in the metal door skin at about half way up and 3/4 over the width of the door towards the lock. Unfortunately this hole is under the foam sound / water insulation cover stuck to the door. feel for the hole and cut a small hole to access. Repair / reseal with gaffa-ape or similar. Be careful tightening up the bolt it clamps two metal plates, one each side of the glass. So I assume overtightening will break the glass. Anyway, you'll find it easyish. I did this and it was fine and never came loose again. It took a while first time but could do it in about 20mins now i know what to do.
I'm on my second Zed, a cosseted 2007 Interlagos Blue Z4M Roadster owned since new - 343 horses controlled by a donkey...
Daily driver is a 2012 X3 3.0d M Sport (fantastic) Wife has a 2015 325d Luxury
IAM Observer
IAM Observer
Hi from a long time lurker with a 2003 3.0 which has the same problem (and all the others ).
There is, I believe, a BMW fix for this in the form of a clip which supports
the clamp which holds the glass. Modified parts were introduced into production after 3/04.
It appears that to fit the clip or tighten the clamp you do not need to strip out the interior
door trim. Instead, access is via the exterior door handle, which has to be removed.
BMW technical sheet SI B51 04 04 covers the clamp and door handle removal is
section 51 21 170.
Now, the problem . These TIS sheets were on http://www.tis.net, which now appears to be
http://www.bmwcenternet.com and you have to enter a dealer code & password to get the info.
Can anyone here access this site please? Failing that, does anyone know how to remove
the exterior door handle correctly? Once it is off, the window clamp is easily accessible.
Thanks in advance
section 51 21 170.
Thanks in advance
Hi again. My mistake, the interior trim has to come out to remove the door handle.
"ian in lancs" has the solution spot on. I can totally agree that the second time you do it will be a lot easier!
Useful photos on trim removal in the Z4 section of diy instruction on http://www.bimmerforums.com. The thread
title is "Z4 door handle LEDS-DIY"
