Rear Light Facelift Update Cheap How to
kis
Post by kis » Tue Aug 30, 2016 7:36 am
jaimebt wrote: images are not showing up :( could you verify the links?
sorry for the trouble, you will really help me out.
my best regards!
+1 pictures would be useful! I'm considering taking the plunge!
Thanks in advance :thumbsup:
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
85genius
Post by 85genius » Tue Aug 30, 2016 8:13 am
my best regards!
To anyone wanting images read the whole thread there are other photos in there and also a much easier method than shown in the first post
Audi quattro driver :o
NOW SOLD - Ruby Black 3.0 SI Roadster :(
Previous - E85 2.5 Ti Silver - See avatar photo - R.I.P Destroyed by a Tranny
Gr3g4
Post by Gr3g4 » Mon Feb 20, 2017 8:34 pm
Hello. Can I code the car while old lights are still connected? Will this damage anything because of the higher voltage? I need this because the body work will be done by one guy and the electricity and coding by the other. That's why I would like to make the coding first at the electricity guy and drive with old lights to the body shop.
Gr3g4
Post by Gr3g4 » Mon Mar 27, 2017 1:21 am
yg54sg wrote:* the correct procedure would be to use a metal saw and saw out the new holes on the body panel behind the light cluster BMW actally provides a template for this... however since I have never replaced a bulb in the 5 years I have had the car i dont see why I should saw up part of the metal on the car. Using my method if you really have to change a bulb just undo the 3 nuts and let the whole cluster come out, takes 2 minutes! The lights fit perfect and you can still change the bulb easily... so no hard done!
Where can I get this template? I will do a repaint so I would like to cut the holes as in facelifted model.
kis
Post by kis » Mon Mar 27, 2017 10:07 am
Gr3g4 wrote:Hello. Can I code the car while old lights are still connected? Will this damage anything because of the higher voltage? I need this because the body work will be done by one guy and the electricity and coding by the other. That's why I would like to make the coding first at the electricity guy and drive with old lights to the body shop.
Or maybe vice versa mate. Could wire everything up (correctly to facelift) and leave the lights off till you get the chance to code them. Not having enough voltage can't do harm? But I'm sure having it the other way round would...
Will also be in the same boat so nice to know what options are available :)
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Gr3g4
Post by Gr3g4 » Mon Mar 27, 2017 10:31 am
@kis we decided to play it safe and do the coding at the body work garage.. :)
I'm still searching for the FL body hole template for rear lights though...
spun
Post by spun » Wed May 24, 2017 3:31 pm
Hi. Only a stupid question. How is the way to go to change the pins because its possible to cut cables and reconect but how You conect the pin un the empty space for example?thanks
Z4R 3.0i M54 55k km - VF supercharger - ESS performance exhaust - Kw suspension - 135I Brembo 6 pot Brakes - Cobra misano Seats - ... Image
kis
Post by kis » Wed May 24, 2017 6:08 pm
Pins inside the car connector? They should unclip from inside. I think you push the little tab down then if you pull the wire it should come out. You can then reposition where necessary...
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
spun
Post by spun » Wed May 24, 2017 7:05 pm
Thanks! Is not neccesary to cut anything.easier than i think. Thanks to all
-banned-
Post by -banned- » Thu Sep 07, 2017 12:24 pm
Some guy on instagram fitted facelift lights without replacing the bumper ,looks like good fit to me and less hassle.
Z4m coupe :driving:
jamie_z4
Post by jamie_z4 » Thu Sep 07, 2017 3:45 pm
ahh our mate Marius - how is he :evil: :lol:
18 Z4s owned to date.
Current: 2.5i Titan silver
kis
Post by kis » Fri Sep 08, 2017 12:11 am
For what it's worth a rear bumper should be pretty cheap to pick up 2nd hand and in the right colour too. Finishes it all off nicely. Slightly different lines too...
It's if you're after a M bumper that you'll need more dolla!
Sorry about some pics. Best ones I could find in Titan to match and compare Marius's one.
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
-banned-
Post by -banned- » Fri Sep 08, 2017 8:35 am
Title says Cheap how to. Surely it's not cheaper to buy lights, bumper and respray then just buy and fit lights with existing bumper.
Z4m coupe :driving:
IAmOrion
Post by IAmOrion » Tue Dec 19, 2017 6:59 pm
Sorry to dig up an old thread,but I will be attempting this most likely in the morning or at least over the next few days... can someone confirm the easiest / best route to take?
I have the facelift rear lights, the facelift surrounds, and an M facelift rear bumper so really it's just the light wiring / coding I need confirmation on. Does it have to be done via NCSExpert? Can it be done with Carly? (I ask as even though I have ncsexpert working, I've no idea how to use it) and is it as simple as changing the wire order in the plug as found in this guide here: https://www.motor-talk.de/blogs/audi-a3 ... 19777.html
Many thanks in advance
NO LONGER OWN A Z4 SO NOT AS ACTIVE HERE ANYMORE (IF AT ALL).
I STILL OFFER FREE CARLY CODING & EWS KEY/TRANSPONDER CODING AT MY HOME
IN CAMBRIDGE CB22
Facebook: https://www.facebook.com/groups/Z4DIYCustomMods/
IAmOrion
Post by IAmOrion » Wed Dec 20, 2017 5:41 pm
Nevermind.... All done & sorted in a morning including the NCSExpress coding :)
(Excuse the boot being open a fraction! Also, Quad exhaust is next mod on the list)
IN CAMBRIDGE CB22
