carbon wraping dash and console now done looks great
- Rudd
Re: carbon wraping dash now done looks great
The only query i have is what does it feel like to the touch? is it fragile and will wear easily or quite durable.
for things like the handles you want it to be quite durable obviously, how is yours holding up?
did you get yours from ebay?
cheers
richard
cheers
richard
- srhutch
- Moderator
Doenst seem fragile as long as the ends are all covered as I guess it will fray being true material.
I have posted some pics on here of it against my CFL dash, but cant remember where they are.
- Rudd
i think i remember the post. i will have a dig around.
there is some on ebay quite cheap, and i guess you just use 3m or similar sray adhesive?
- z4phill
This stuf feels and looks like ths real thing and it is extremly tough, I got it realy hot when applying and it only streched when I pulled it round the coners and as long as you wrap it round and tuck under I dont think it will ever fray or peel off , easaly avalable on ebay mine was 600mm X 1200 about which is more than enough to do all the bits on the zed £35 with the postage off ebayz4phill wrote:here is the ebay item no 190385132665 3m di-noc carbon fiber vinylsrhutch wrote:Have you got the link to the CF you bought. I assume it's fabric like I bought, but mine seems a little to shiney where as yours appears to me more matt effect.
- z4phill
Re: carbon wraping dash and console now done looks great
just done the console today come up really well the car had to come to bits to remove the alloy but it was worth the hastle what do you think
- Craig74
Looks great...
I would also like to do this but worrie about rattles after the dash has been apart?
C
C
Black 07 3.0l si sport Z4 Coupe, Xenons, Cruise Control, Pro Nav, BT phone Prep, Comfort pack, Speaker upgrade, Stubby, 19 225M Wheels, Heated Electric Seats,
- srhutch
- Moderator
Theres notihng to woory about regarding the dash rattling, as you only need to remove the centre vent and sterro which most people have done, and the trim is held on by four screws and one clip. The piece round the light switch just pulls off.Craig74 wrote:Looks great...
C
The centre console on the other hand requires half the interior to come out, but if you take your time there is no reason why it should rattle afterwards.
- Taz
looks good, i'm impressed
- Rudd
that looks great!
did you take any pics of taking the centre console out? im going to go for this!
- Dreamer
Really suits the cream interior
How long did it take to get the console in and out?
///M Interlagos. Champagne leather
- z4phill
I took the seats out first then removed the center rear cuby just remove the two screws below the door and the two large ones under the cover at the top it all unclips without to much drama . once this is removed the console comes out by removing the two knee pads I put a screw driver on the lower side of the pad and prised them off then removed the screw covers it all just slides out
the console took me about 2 hours in total to remove put the wrap on and replace and while the seats where out give the the car a good vac , I took the car out for a run and and to show a couple of mates they cant belive the finish one said it looks like it left the showroom with that dash , I have no rattles only problem I have is I keep looking down at my new dash as I am driving I hope to stop doing this as I dont want to put the car through the hedge
looks great - how about the silver bits on the wheel, im tempted to do this so much, but need to get alignment done first and finish off my headlight project.
- a11y
That's a superbly done job - good job
I've got an A5-sized free sample of that stuff but as yet I've been unsure what to do with it - nothing car related as it'd barely cover one wing mirror lol so probably cover my phone or something. Not sure I'd do this on mine as the aluminium lifts the otherwise dark combination with my seats and trim.
im the same, black interior with silver trim, but i think of the wrap as a nice change plus it protects the trim too.
- srhutch
- Moderator
You took the seat out , no need to do that to remove the centre console.z4phill wrote:I took the seats out first then removed the center rear cuby just remove the two screws below the door and the two large ones under the cover at the top it all unclips without to much drama . once this is removed the console comes out by removing the two knee pads I put a screw driver on the lower side of the pad and prised them off then removed the screw covers it all just slides out
