Change your Air, Oil and Oil Filter
Re: Change your Air, Oil and Oil Filter
Where exactly do you put the jack stand?
does the oil filler cap has a torque #?
- AndyMc
I am planning on doing this how to on Saturday but I have a N52 engine..
What do I need to do differently? The oil filter cap is different? How do I remove it, do I need the special size wrench?
Andy
iPhone using Tapatalk
Andy
Z4 3.0si Stubby
Great post!!! Many thanks!
I'll be doing mine on Friday.
Anyone know what happened to the images on this post? or if there is another one?
- sk93
The server I was hosting them on up and died on me :/
I will try and find the originals and repost in the next week..
- Woots
- sk93
see here: http://www.z4-forum.com/forum/viewtopic ... 65#p804465Woots wrote:Where the hell have you been?
I've also been working on my Charger.. though I'm pretty positive once I get through my Zeds MOT, I'm just gonna put the charger up for sale.
Far too much effort for extremely little gain
(had to fly to the states just to organize shipping a few gearbox internals across... )
sk93 wrote:The server I was hosting them on up and died on me :/
Thanks mate, that would be great!
- CUREthe
...where is the pics of process?
Smart Pulse CDI 02' Bay Grey
BMW E30 316i 90' Delphin Metallic
BMW E85 2.2i Roadster 04' SterlingGrau Metallic
- sk93
blah... i've been too busy to get this done :/
I've got the fluid and filter ready to go.. just need to get the darn time to do it
maybe someday this week if all goes well
never personally been told off by hot oil ! mrs mad 4, regularly !! good write up for newbies or non mechanically minded souls
- lukez4
Bit of a bump
What is the oil capacity on a 2.2 se z4? Iv put in almost 5 litres and it's just on minimum?
Sent from my GT-I9505 using Tapatalk
- Grumpyowl
lukez4 wrote:Bit of a bump
If you've changed the oil filter it should be 6.5ltr.
Agree a very good right up but no dip stick found on my 2.5 E85 N52 Engine ? You mention on step 16 :
After a minute, turn off the engine and check the oil level via the dipstick. The first time you check, it should be close to, or just above the minimum mark.
If it is low, carefully add another 0.25 of oil, run the engine for a minute and repeat this step.
It should only take one litre of oil to raise the level from the minimum mark, to the maximum.
The stated oil capacity is 6.5 litres, so if you need to add much more than this, check that the new oil is not leaking from either the sump plug, or the oil filter cover.
Be very carefull and do not overfill the engine with oil, as this can be very damaging. If you DO add too much, unscrew the sump plug slightly and allow some oil to drain.
Any idea where to find it ??
- Smartbear
there is no dipstick on the n52 engine, you have an electronic dipstick on the led speedo display instead.Cristo wrote:Agree a very good right up but no dip stick found on my 2.5 E85 N52 Engine ? You mention on step 16 :
regards
e85 3.0si sold
