Tried to replace my cabin air filter today (first time), but couldn't find the thing! Followed the instructions shown by MicronAir, which seemed pretty thorough. I got the panel off below the glove box (LHD), spotted the General Service Module, but did not disconnect, but I could see nothing that looked like an air filter?
Any body have any pictuires or better instructions? The Bosch site seems to be no longer working.
Thanks.
How to replace cabin air filter?
- sbtwister
Alpine white Z4 3.0i, Dream red leather, M-sport seats, suspension, Xenons, Hot seats, Prem. sound, XM Radio, Aux in, Strut brace, Black grill, CF Roundels, Stubby, Half foam, MM Tips.
- sk93
- sbtwister
Re: How to replace cabin air filter?
sk93 - Yeah tried these. I followed the MicronAir instructions, but saw nothing resembling an air filter? The Bosch link seems to be broken....
- sk93
http://www.boschautoparts.com/Technical ... lation.pdf
page 11, but these are the same instructions as the MicronAIR.
I know it's a silly question, but you do have a filter?
- AlanJ
http://www.ehow.com/how_4554745_cabin-a ... bmw-z.html - as simple as this!
Hi there, funny i have just replaced the filter on my ZED, if you had the panel off you are half way there, ok mine is R/H drive and looking up under dash ( a bit awkward i know and you will need a good light) there is a rectangle shaped cover approx 8" x 3" press the clip at the bottom and it will slide down and off , you need to be a bit flexible, but like all things when you 've done it once its easy, be carefull of all the rubbish when you pull the filter out, hope this helps ///////// david
- sbtwister
Thanks for the help. I assume that all Zeds have the cabin filter, so I don't think my search is in vain...
Guess I'll get in there again next weekend. The instructions from ehow.com seemed a little different, because they talk about removing the glove box. Is this the case or is it rather remove the panel in front (towards the engine) of the glove box?
As stated previously, I got to the point of finding the General Service Module (the white box in the MicronAir pictures), but have yet to find the elusive filter.
You dont need to remove glovebox, as i said use a good light and you will see the cover.
