Do I recommission my M Sport suspension?
Reamesy
Post by Reamesy » Thu Jun 26, 2025 6:51 pm
When my car was new it had M Sport suspension delete as an option back in 2011. My car is a 23i M Sport Highline.
There is nothing wrong with it but as it has covered 52K I thought the shocks could do with a refresh as they are also 14 years old.
Now I looked on Real OEM and the springs are no longer listed. So I was thinking of going down the Suplex M Sport springs route with Bilstein B8 shocks and new top mounts. £711 form Autodoc
Or do I just replace the shocks like for like (Sachs) and stick with a softer ride for around £350 plus new top mounts form Autodoc?
Anyone else done this or suggest an alternative as close to original as possible? I don't want coilovers.
Currently; 2011 E89 23i SDrive M Sport Highline Titan Silver
Previously;
2014 SLK250CDI AMG Sport
2012 E89 SDrive 2.0 M Sport. White
2011 Audi TT Quattro
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
B21
Post by B21 » Thu Jun 26, 2025 9:17 pm
New shocks won’t hurt..but..if you spend £350 and it’s not the revelation you’d hope for… 😢
One of 258 Atacama Yellow 35is…165 modifications and updates…and counting.. :tumbleweed:
Reamesy
Post by Reamesy » Thu Jun 26, 2025 9:49 pm
But do I go to M Sport stiffness or stay stock? Currently have no issues but sometimes you don't know how bad something is until it's renewed.
How bad or good is the M Sport over standard? I think that is my real question.
Previously;
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
Online
RMB
Post by RMB » Thu Jun 26, 2025 9:53 pm
I think it depends on your wheels and tyres too. 18/19 normal or rft.
You should get a slight drop in ride height too I guess so it may look a bit better.
2006 E85 2.5i manual, Montego Blue “Monty”
2017 F22 M240i Estoril Blue “Mr Z”
2009 E82 123d. Space Grey. “Turbo Bus” Gone
2004 E46 M3. Vert. Silver Grey. Gone.
2003 E46 330ci. Mystic Blue. Gone
Rockhopper
Post by Rockhopper » Fri Jun 27, 2025 9:14 am
Your current shocks and struts will be knackered by now so whatever you do will transform the car. Msport is about 15mm lower than standard as well.
B21
Post by B21 » Fri Jun 27, 2025 9:51 am
Reamesy wrote: Thu Jun 26, 2025 9:49 pm But do I go to M Sport stiffness or stay stock? Currently have no issues but sometimes you don't know how bad something is until it's renewed.
I’ve ridden now in several other E89s as well as my two…unless you’re tracking it or really hooning the stock ride height is nice..you could use B6s and stock springs for the best of all worlds
ARCS
Post by ARCS » Fri Jun 27, 2025 11:16 am
I went from SE suspension to B8's paired with Eibach pro springs, and I'd say the ride quality improved. My SE suspension was probably shot anyway.
2009 E89 23i Alpine white.
2008 cayman 2.7 Arctic silver.
2003 E85 3.0 titan silver - sold
Reamesy
Post by Reamesy » Fri Jun 27, 2025 12:01 pm
Cheers team. Food for thought🤔👍
Previously;
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
1536Z4
Post by 1536Z4 » Sat Jun 28, 2025 12:50 pm
The state of the roads round Whitchurch area I wouldn`t go M sport :thumbsup:
Z4M SG Supercharged .DCT transplant see here viewtopic.php?t=138219
Montego Blue E86 3.0 si. Modifications build post here viewtopic.php?t=143997
Rockhopper
Post by Rockhopper » Sat Jun 28, 2025 12:58 pm
New Msport will feel like you are floating on a magic carpet compared to knackered standard springs and struts. Even my Mrs noticed the improvement when I did mine.
Reamesy
Post by Reamesy » Sat Jun 28, 2025 1:25 pm
1536Z4 wrote: Sat Jun 28, 2025 12:50 pm
Yes I’m leaning towards current and full refresh 👍
Previously;
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
B21
Post by B21 » Sat Jun 28, 2025 4:53 pm
MSport on E85/E86 is very different to E89 MSport..the E89 MSport is much plusher
Reamesy
Post by Reamesy » Sat Jun 28, 2025 5:44 pm
B21 wrote: Sat Jun 28, 2025 4:53 pm E89 MSport..the E89 MSport is much plusher
Suplex springs appear to be the nearest option to M Sport which if I’m correct are no longer available.
Previously;
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
B21
Post by B21 » Sat Jun 28, 2025 6:09 pm
Reamesy wrote: Sat Jun 28, 2025 5:44 pm
Supplex v good choice..respect !
Reamesy
Post by Reamesy » Sat Jun 28, 2025 8:04 pm
B21 wrote: Sat Jun 28, 2025 6:09 pm Supplex v good choice..respect !
Suplex it is then :thumbsup:
Previously;
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
