Service today by independent I use
Busterboo
Post by Busterboo » Fri Jun 06, 2025 10:57 pm
F.y.i.
2010 35iS 110k miles
Engine Oil (Castrol 5/30) & Filter £165
Pollen Filter £45
Plugs £110
Air Filter £35
Brake Fluid £35
Rear Brake Pads £45
Rear Discs (BMW) £182
Labour £180
Vidi, vici, veni
john-e89
Post by john-e89 » Fri Jun 06, 2025 11:02 pm
Labour £80…? Did he pop over on a dinghy, leave your old parts on and sell the rest for cash to a Romanian mate Buster…? :?
Black M roady
Black E85 3.0 si manual
Mineral grey E89 35is
Black E89 35i manual
2 red MR2 mk 2 T bars
Busterboo
Post by Busterboo » Fri Jun 06, 2025 11:37 pm
:oops:
You're right, of course, John.
I've corrected it.
Vidi, vici, veni
flybobbie
Post by flybobbie » Sat Jun 07, 2025 7:39 am
Oil and filter £165? Must include £100 to put it in.
Avityesboy
Post by Avityesboy » Mon Jun 09, 2025 11:25 pm
Done oil service on mine the other day 35i, 10l litres of ll04 spec oil, Bosch filter £40 for all. Nice 20 min job..
If it’s LL04 spec no point spending any more…IMO
Rockhopper
Post by Rockhopper » Tue Jun 10, 2025 10:57 am
Is the price for disks and pads for both sides or is it x2?
Fady
Post by Fady » Tue Jun 10, 2025 7:18 pm
Avityesboy wrote: Mon Jun 09, 2025 11:25 pm Done oil service on mine the other day 35i, 10l litres of ll04 spec oil, Bosch filter £40 for all. Nice 20 min job..
20 mins to do an oil change? Curious as to how you are raising your car - takes me as long to assemble tools!
My last year's service was done at an indie shortly after acquiring my 2012 N20 which was on 72K miles. I wanted a proper once-over since I bought privately. Bill was circa £700 with VAT. Don't know if OP has included the VAT but mine similarly required rear discs and pads which was charged at £89 for pads, £25 for sensors and £70 for discs all with the VAT on top.
Having done just over 2K miles in the year since then, I decided it didn't really warrant going into a garage to get fleeced so just settled for a DIY oil change. Yes oil and filter but if you don't have a car lift etc. then you need 2 trolley jacks and a set of jack stands. I guess you could also use ramps if you can get them wide enough and are comfortable with that. Then there is the filter tool, a drain pan and ideally a torque wrench. Had everything except the filter wrench which admittedly doesn't break the bank but cost is 'only' 40 quid if you have already got all these. Doing things safely and deliberately took me over an hour.
Also have to allow minutes for checking the actual level once filled since there is no manual dipstick!
E89 28i M Sport Manual White, Coral Red, 19's, Quad Exhaust, iDrive, SmartTop, MatchUp8 Amp, etc.
Other Cars: Mercedes E63 V8 Biturbo Estate , BMW X4 M40i G02
Reamesy
Post by Reamesy » Tue Jun 10, 2025 7:57 pm
One trolley jack under the central jacking point at the front. Two jack stands. Drain plug out into a drain pan. New filter using the filter tool. I change my oil twice a year so worth it as it doesn’t mangle the filter housing. 30 mins tops
6-6.5 litres of new oil. Always bang on the correct level. Reset using service using Autel or you can do it manually. :thumbsup:
Currently; 2011 E89 23i SDrive M Sport Highline Titan Silver
Previously;
2014 SLK250CDI AMG Sport
2012 E89 SDrive 2.0 M Sport. White
2011 Audi TT Quattro
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
B21
Post by B21 » Tue Jun 10, 2025 8:29 pm
To be pedantic there are now much much better oils for a N54 than the basic LL04 spec…it’s a very low bar..the world has moved on..for a N54 an oil meeting API-SP or SN+ would be much better than an oil that just meets LL04..FWIW
One of 258 Atacama Yellow 35is…165 modifications and updates…and counting.. :tumbleweed:
Scooba_Steve
Post by Scooba_Steve » Tue Jun 10, 2025 9:45 pm
For the N54: "1) For petrol engines, only BMW Longlife-04, BMW Longlife-12 FE and BMW Longlife-19 FE oils are permitted in Europe (EU plus Switzerland, Norway and Liechtenstein). They must not be used outside this area."
3.0si Sport. F10 520d.
Avityesboy
Post by Avityesboy » Thu Jun 12, 2025 11:18 pm
Yeah luckily had use of a ramp
B21
Post by B21 » Fri Jun 13, 2025 10:19 am
Scooba_Steve wrote: Tue Jun 10, 2025 9:45 pm For the N54: "1) For petrol engines, only BMW Longlife-04, BMW Longlife-12 FE and BMW Longlife-19 FE oils are permitted in Europe (EU plus Switzerland, Norway and Liechtenstein). They must not be used outside this area."
A more insightful expose on the life and times of BMW oil approvals is here..
https://www.bimmerworld.com/BMW-Engine-Oil/
For the N54 an oil meeting API-SN+ or API-SP in a 5W-30 0W-30 or if hard driven 5W-40 are the current gold standards ..
Some of those oils will certify their BMW compatibility but since N54s are now 10 years out of production wasting time labelling these for obsolete designs are not their priority ..
Avityesboy
Post by Avityesboy » Sat Jun 14, 2025 12:36 am
An LL04 is fine, I’ve never heard of an engine failure due to non compatible oil tbf on anything tbh.
Only times are when the engine has f**k all in it…
B21
Post by B21 » Sat Jun 14, 2025 7:14 am
Avityesboy wrote: Sat Jun 14, 2025 12:36 am An LL04 is fine, I’ve never heard of an engine failure due to non compatible oil tbf on anything tbh.
Of course an LL04 oil is fine..I’m simply saying there are now better oils than oils that just meet LL04 spec…
Since that spec was formulated the world found out a lot more about sludge and varnish formation, cam chain wear and low speed pre ignition which only affects turbo petrol engines…SN+ and SP address all those issues..an oil just meeting LL04 does not..
Just as an ester based oil that does not explicitly meet LL04 such as Fuchs or Redline ester based oils will far exceed the engine protection of a base LL04 oil is
Each to their own..
Bombur
Post by Bombur » Sat Jun 14, 2025 7:47 am
Reamesy wrote: Tue Jun 10, 2025 7:57 pm One trolley jack under the central jacking point at the front. Two jack stands. Drain plug out into a drain pan. New filter using the filter tool. I change my oil twice a year so worth it as it doesn’t mangle the filter housing. 30 mins tops
Did mine on Rhino Ramps no problems at all
2009 Z4 2.3i
2002 Z3
