E85 roof motor impeller fitting
charlestblue1
Post by charlestblue1 » Sun May 11, 2025 5:18 pm
Hi all, be gentle this is my first post :) 2005 e85 I’ve separated the roof motor and hydraulic pump to change motor but the impeller, a pin and a spring fell out… is there a diagram how this should go back on please ?
bigwinn
Post by bigwinn » Sun May 11, 2025 5:31 pm
It’s something everyone has done so don’t worry!
The plastic circular part with holes in it sits on the spindle with the metal square locking it in place. The spigot with the spring sits in the hole on the pump side and marries to any hole in the plastic part.
On the pump side the circular part sits on the corresponding pole, the three metal dowels sit in the three holes on the outer circumference of the metal spinner
When you marry the two halves together don’t forget the rubber seal
EWS Delete PM me
Coding- airbags etc PM me
GM5 repair- PM me
Roof problems? E85 and E89 PM me… E86 less so
charlestblue1
Post by charlestblue1 » Mon May 12, 2025 8:32 pm
Thanks so much…
