The definitive guide to BMW Z4 E89 big brake kits
How-To articles are in here.
B21
Post by B21 » Wed Feb 26, 2025 3:17 pm
Given the passage of time I thought I'd refresh /update /add to the options now available.
There are a number of options
Upgrade within known E89 family eg 35is rear brake on other models
BMW family upgrades eg using F series Brembo calipers
Non BMW family ugrades eg using Ford Mustang calipers
Custom designs from Alcon, Ceika, PB brakes etc
I've created a table with a wealth of calculations looking at various aspects including brake forces, master cylinder issues and front/rear balance.
https://www.dropbox.com/scl/fi/f23ccya8 ... yen0z&dl=0
https://www.dropbox.com/scl/fi/rt7ceuw6 ... l74bi&dl=0
I've covered all the E89 permutations, F series Brembo 4 pot fronts in 340/370/380mm, E90 Brembo 6 pot fronts, Mustang GT350 Brembo fronts, Alcon CP8520 fronts and B21 5 series 345/370mm rear and PB Brakes 6 pot 356mm rear for E89
For the sad bunnies some very interesting data.
What the data doesn't show /can't easily show is
Thermal capacity and heat dissipation of both discs and pads
Impact of changing pad material /type
More to follow
One of 258 Atacama Yellow 35is…165 modifications and updates…and counting.. :tumbleweed:
The.Analyst
Post by The.Analyst » Wed Feb 26, 2025 5:14 pm
Do you have nothing to do with your time ?
Great piece of work
Interesting to see what you assume is not so
Spending time with a 35i, previous convictions: Fiat 20V Turbo Coupe, TVR Chimera, Jaguar XKR, Porsche 997 C4S
B21
Post by B21 » Wed Feb 26, 2025 8:13 pm
The.Analyst wrote: Wed Feb 26, 2025 5:14 pm Do you have nothing to do with your time ?
Great piece of work
Yes a few surprises in there when you do the maths…essentially the answer is bigger diameter discs then bigger / more pistons.. :thumbsup:
LittleBlackHawk
Post by LittleBlackHawk » Fri Apr 18, 2025 3:35 am
this is an excellent work. would it be possible to add Brembo GT6 to the chart? Thank you very much.
B21
Post by B21 » Fri Apr 18, 2025 11:07 am
LittleBlackHawk wrote: Fri Apr 18, 2025 3:35 am this is an excellent work. would it be possible to add Brembo GT6 to the chart? Thank you very much.
Do you have a link to a 'GT6'? :tumbleweed:
