What have you done to your E89 today
Online
B21
Post by B21 » Thu Jan 16, 2025 7:01 pm
enuff_zed wrote: Thu Jan 16, 2025 6:15 pm :D
Zed Baron wrote: Thu Jan 16, 2025 6:05 pm I wonder how fast it will go now with all that mud and gravel removed :rofl:
Hopefully now it will be quick enough to prevent other ‘lesser’ zeds running into the back of it. :poke:
Should never have stopped at the Give Way… :tumbleweed:
One of 258 Atacama Yellow 35is…165 modifications and updates…and counting.. :tumbleweed:
Christopher72
Post by Christopher72 » Fri Jan 17, 2025 10:18 pm
Good time to polish those exhaust tips while your cover is out of the way....
Christopher
2011 E89 Sdrive35i - Deep Sea Blue, Beige Kansas Leather
'fits in progress - PDC, Cameras, Comfort Access, Respray/Correction - all queued for poor weather.
(9) E46 convertibles; (1) E39 540i; (2) E36 Z3 roadsters; (1) Pre-prod E36 Z3- all gone
sakamoto
Post by sakamoto » Fri Jan 17, 2025 10:47 pm
The other day, I washed the car and the silencer case behind the rear left tire was abnormally rusty, so I hurriedly applied rust prevention. It also served as a rust remover, so it became shiny.
Is it related to the winter freezer?
How are you guys
:thumbsup:
Online
B21
Post by B21 » Fri Jan 17, 2025 11:19 pm
Christopher72 wrote: Fri Jan 17, 2025 10:18 pm Good time to polish those exhaust tips while your cover is out of the way....
Yup.. :thumbsup:
Bombur
Post by Bombur » Sat Jan 18, 2025 8:21 am
sakamoto wrote: Fri Jan 17, 2025 10:47 pm The other day, I washed the car and the silencer case behind the rear left tire was abnormally rusty, so I hurriedly applied rust prevention. It also served as a rust remover, so it became shiny.
What did you use?
2009 Z4 2.3i
2002 Z3
sakamoto
Post by sakamoto » Sat Jan 18, 2025 9:41 am
It is a manufacturer that handles maintenance in Japan, but it became shiny, and I couldn't do it in every corner because I didn't lift it up
:thumbsup:
Bombur
Post by Bombur » Sat Jan 18, 2025 11:25 am
I didn't think there were corrosion issues in Japan compared to here
2009 Z4 2.3i
2002 Z3
sakamoto
Post by sakamoto » Sat Jan 18, 2025 12:12 pm
The car I bought was used in a snowy region, so it has a lot of rust. In addition to the muffler, metal parts such as screws and arms have rust and need maintenance. I found a rust inhibitor on Amazon, so I'm attaching a picture.
:thumbsup:
Online
B21
Post by B21 » Sun Jan 19, 2025 6:57 pm
Attention moves to the front end..the existing BBK..the trusty E82/E90 6 pot Brembo with 338mm x26mm discs removed for the new owner..
Current plan is still to fit the big Shelby Mustang Brembo 6 pot (bigger pots) with M2/M4 380mm 30mm discs..
However here’s the F series M Performance caliper (340m with adapter for 380mm discs)…
Also trial fit of 380mm M2 front dust shield..will need a little work but 3 out 4 holes line up..
The M Performance caliper is slightly lighter..the old Brembo s bit chunkier..but it does have harmonic weighs bolted on..
Enjoy..
sakamoto
Post by sakamoto » Mon Jan 20, 2025 12:21 am
I'm using the E90 Mpkg brembo on the far right with a different color, and when I checked with the shop, it seems that this caliper doesn't fit 360mm and the pad area disappears
:thumbsup:
Online
B21
Post by B21 » Mon Jan 20, 2025 10:17 am
sakamoto wrote: Mon Jan 20, 2025 12:21 am I'm using the E90 Mpkg brembo on the far right with a different color, and when I checked with the shop, it seems that this caliper doesn't fit 360mm and the pad area disappears
I haven’t looked at that option so can’t advise..
Big Andra
Post by Big Andra » Mon Jan 20, 2025 3:09 pm
This thread should be renamed, what has B21 done to his e89 today :rofl:
2009 E89 2.5 Alpine white.
2008 cayman 2.7 Arctic silver.
Online
B21
Post by B21 » Mon Jan 20, 2025 6:16 pm
Big Andra wrote: Mon Jan 20, 2025 3:09 pm This thread should be renamed, what has B21 done to his e89 today :rofl:
Well..come on guys..get in with the twiddling and upgrades.. :poke: :tumbleweed: :thumbsup: :rofl:
Online
B21
Post by B21 » Mon Jan 20, 2025 6:34 pm
Brackets for the 345mm E89 rear BBK arrived from the shop..
Online
Pondrew
Post by Pondrew » Mon Jan 20, 2025 8:43 pm
Yes, cos there are nowhere near enough of those threads already. :D
2024 Audi A4 avant 40 black edition petrol
2025 Ford Focus ST 'track pack'. Go-kart with sat nav.
Z3 'free litre'. Project and a half.
No Z4 anymore!
