- The key fob will still remotely unlock the boot without any issues and the spare fob is the same.
- The car starts / drives fine and there are no codes related to this
- The central locking does not work either off the remote key, via the central lock button near the handbrake, or from turning the key in the drivers door.
- The drivers side window (passenger is fine) will not fully raise, (well it will for a split second but then drops again, as if you've got the door open). I think the car thinks the door is open even when it isn't. As it's a pre facelift model, it doesn't have the indicator on the dash.
- The interior lights are not coming off / on when they usually do
- I removed the GM5 Module and sent this off to repair via a guy on Ebay that comes with great feedback, as all these symptoms pointed to a busted GM5 module. Other than a 'yes definite faults on the PCB' message from the chap on Ebay, I don't know what exactly was wrong with it, but putting the 'fixed' GM5 module back hasn't fixed the central locking issue.
I'm now at a loss as to what to do next and could really do with some help.
