Was inspecting the new (to me) car more thoroughly and noticed the driver side fog light was dislocated. Looks like previous owner hit something gently and pushed in some of the plastic and jarred the fog light. However upon inspection noticed some kind of sensor/camera mounted under the bumper centerline.
Followed the wiring up to the firewall and through the passenger side. Crawled under and found a speaker (?) and a screw that definitely doesn't look factory (far right in image). Don't have time to pull apart the under dash right now so couldn't get more info.
Is this some kind of front park assist? Maybe installed after he banged up the fog light would be my guess. But the little bumper mount camera looking thing is what is throwing me off. When I look at aftermarket parking sensors kits they don't have such a thing.
Aftermarket front parking assist?
- DMike
Just guessing, but in addition to a front parking sensor, could that be a radar detector/jammer? Whatever it is, under that panel you might find the module.
2005 Z4 3.0i Sterling grey
- enuff_zed
Lovely bit of hacking and bashing gone on with that panel!
Looks like a speed camera detector.
And also looks like someone cut that hole out with a bread knife.
2009 09 Carbon Black Cinnamon E86
My suspicions were correct. The device is called a Curb Alert Pro \https://www.amazon.com/Brandmotion-5000-CA5-Alert-Warning-System/dp/B0058OCKXI?th=1
I'm guessing he hit that bump then got this installed immediately after. The speaker wasn't connected to the actual unit so I've never heard it actually go off since I've had the car. Hooked it up and it definitely does work still. The extra screw was for how they mounted this thing...woof terrible install :thumbdown
