WANTED z4 E85 yaw sensor/module
Does anyone have a yaw sensor, the one under the passenger seat, for sale for a E85 3lt
Onlinebigwinn
What age? They differ from facelift/prefacelift
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
Online
If it’s a Facelift… I have one .and it’s under the Drivers seat unless you are a Lefthand drive region.
Its 03 pre face lift
- enuff_zed
At least they are the cheaper ones.
But do you know why it's failed? Is it soaked under there?
Don't know yet, the Z is just having a quick service and the usual three lights were on, code came up pointing to the yaw sensor, the guy knows his Z's so hoping he is right.
- enuff_zed
Sounds about right, but it's most often due to water ingress. Push the seat fully forward then slide your hand in through the join in the carpet.
No point fitting a new sensor if it's wet. But also, if it is, bag up the airbag satellite module at the base of the B-pillar before that succumbs as well.
Thanks for the advice, will update when I get it back from the garage.
Thanks for that but got one of flea bay for £30, the problem is now fixed.
