Best value speaker upgrade from base system?
- thecremeegg
My new M has the basic 6 speaker system which is a bit of a downgrade from the carver system in my other Zed!
From what I understand I don't have speakers in the doors so I would want to add those.
Anyone got any speaker recommendations that aren't hundreds of £ for me?
Thanks!
Thanks!
Z4M - Interlagos Blue with Black Leather
Z4 3.0i - Sapphire Black with Red Leather - FOR SALE!
- enuff_zed
I believe the cheapest option is to use a pair of the standard speakers from behind the seats which are identical to the door ones, then splice them in to the tweeters on the door.thecremeegg wrote: ↑Tue Apr 09, 2024 6:01 pm My new M has the basic 6 speaker system which is a bit of a downgrade from the carver system in my other Zed!
Thanks!
Disclaimer: I have no idea when it comes to sound systems, but I have heard a lot of people say this.
Yes, the speakers that would normally go in the doors are the same as the ones behind the headrests and readily available. You won’t have the wiring pre-installed, hence splice in from the tweeter as enuff suggests.
It won’t match your Carver set-up, sadly
2003 Maldives Blue 3.0i auto
Yep, I've done this..enuff_zed wrote: ↑Tue Apr 09, 2024 6:06 pm I believe the cheapest option is to use a pair of the standard speakers from behind the seats which are identical to the door ones, then splice them in to the tweeters on the door.
It helps LOADS (once you move the balance forward on the HU setting) but still no match for anything modern or half decent.
E86 3.0si - Koni, Eibach, Eisenmann. viewtopic.php?t=143973
F31 340i MPPSK - Carrying family, bikes, kayaks and everything else.
- mr.tourette
A set of Crunch DSX4.2E components in the doors will help and a set of new 4 inch mids behind the seats will make a big improvement to the clarity of the system
I made a thread on my upgrade here viewtopic.php?t=125344&hilit=Crunch
Silverstar made a similar thread on his set up
- thecremeegg
Thanks! So the base system doesn't have tweeters either? I thought it had tweeters as other guides seem to take the feed from that wiring?mr.tourette wrote: ↑Tue Apr 09, 2024 9:24 pm A set of Crunch DSX4.2E components in the doors will help and a set of new 4 inch mids behind the seats will make a big improvement to the clarity of the system
- enuff_zed
Yes it does. Tweeters in the door front corners and speakers in the kick panels and behind the headrests.thecremeegg wrote: ↑Tue Apr 09, 2024 10:09 pmThanks! So the base system doesn't have tweeters either? I thought it had tweeters as other guides seem to take the feed from that wiring?mr.tourette wrote: ↑Tue Apr 09, 2024 9:24 pm A set of Crunch DSX4.2E components in the doors will help and a set of new 4 inch mids behind the seats will make a big improvement to the clarity of the system
- thecremeegg
Ah ok thanks, I was confused hah
- mr.tourette
Its been a while but im pretty sure it doesnt, iirc, big woofers in the footwell, 2 4" in the doors and 2 4" behind the the driver make up the 6 speakers.enuff_zed wrote: ↑Tue Apr 09, 2024 10:10 pmYes it does. Tweeters in the door front corners and speakers in the kick panels and behind the headrests.thecremeegg wrote: ↑Tue Apr 09, 2024 10:09 pmThanks! So the base system doesn't have tweeters either? I thought it had tweeters as other guides seem to take the feed from that wiring?mr.tourette wrote: ↑Tue Apr 09, 2024 9:24 pm A set of Crunch DSX4.2E components in the doors will help and a set of new 4 inch mids behind the seats will make a big improvement to the clarity of the system
From what i remember putting in the components made a big difference
Pinched from another forum:
E89 28i M Sport Manual
Other Cars: Mercedes Benz E63, X4 M40i
That diagram is an E89 which is different
The E85/E86 standard 6 speaker is:
2 x woofers in the footwells
2 x midrange behind the headrests
2 x tweeters inboard of the door mirrors
The 10-speaker setup adds:
2 x midrange in the doors
2 x subwoofers in the cubbies behind the seats
An amp in the boot
The top-HiFi set up has:
Different subwoofers behind the seats (30v, so not interchangeable)
Other speakers are upgraded
Carver/DSP amp in the boot
An amp in the boot
- mr.tourette
Oh bugger, didnt realise this was e85/86 in that case its correct it has tweeters but no 4 inch mids in doors.
In that case ..You can put a set of 4 inch mids in doors and take a feed from the tweeters as they recieve a full signal, I've done that mod for another member and its wortwhile
- enuff_zed
Having removed many a door card I can categorically state that the basic 6 speaker system is as I described. The black plastic triangles by the mirrors house tweeters. There are speaker grilles in the doors but they have a plastic blank fitted.mr.tourette wrote: ↑Tue Apr 09, 2024 11:13 pmIts been a while but im pretty sure it doesnt, iirc, big woofers in the footwell, 2 4" in the doors and 2 4" behind the the driver make up the 6 speakers.enuff_zed wrote: ↑Tue Apr 09, 2024 10:10 pmYes it does. Tweeters in the door front corners and speakers in the kick panels and behind the headrests.thecremeegg wrote: ↑Tue Apr 09, 2024 10:09 pm Thanks! So the base system doesn't have tweeters either? I thought it had tweeters as other guides seem to take the feed from that wiring?
- mr.tourette
You are correct mate as I posted up there^^^I mistakenly thought this was e89 not e86enuff_zed wrote: ↑Wed Apr 10, 2024 7:13 amHaving removed many a door card I can categorically state that the basic 6 speaker system is as I described. The black plastic triangles by the mirrors house tweeters. There are speaker grilles in the doors but they have a plastic blank fitted.mr.tourette wrote: ↑Tue Apr 09, 2024 11:13 pmIts been a while but im pretty sure it doesnt, iirc, big woofers in the footwell, 2 4" in the doors and 2 4" behind the the driver make up the 6 speakers.
- enuff_zed
Oh sorry, missed that post.mr.tourette wrote: ↑Wed Apr 10, 2024 3:41 pmYou are correct mate as I posted up there^^^I mistakenly thought this was e89 not e86enuff_zed wrote: ↑Wed Apr 10, 2024 7:13 amHaving removed many a door card I can categorically state that the basic 6 speaker system is as I described. The black plastic triangles by the mirrors house tweeters. There are speaker grilles in the doors but they have a plastic blank fitted.mr.tourette wrote: ↑Tue Apr 09, 2024 11:13 pm Its been a while but im pretty sure it doesnt, iirc, big woofers in the footwell, 2 4" in the doors and 2 4" behind the the driver make up the 6 speakers.
