We looked at that the other day and as far as could tell all ok.
Interior is stripped at the moment, so easy to access again - I'll have another look.
Electrical issues.
Electrical issues.
2005 E85 - Merlot - Appropriately named 'Ron Burgandy'...
- enuff_zed
Electrical issues.
Fair enough.
You slave in another one. You will still get the airbag light but everything else should be ok if it is that.
Electrical issues.
I had very similar issues with mine when I first got it years ago. Mine was a faulty iPod interface, I had the old style apple charging lead in the glovebox, this was plugged into an iPod interface(factory fitted I think) which was located behind the radio. Once i unplugged this module everything cured itself. This is on the canbus circuit so as others have said it is more than likely a corrupt module on that circuit.
Attached is the culprit for me
Jay
Jay
- Screenshot_20240411_175727_Chrome.jpg (92.75 KiB) Viewed 214 times
Electrical issues.
Today's Update!
Progress, we now have most of the components working.
Having done further research on similar issues with the E46, i found this video:
https://www.youtube.com/watch?v=ZT4sQsJ ... %99sGarage
My situation was slightly different as the KBUS was reading ~12v which was why we missed it before.
We then started removing pins and found a culprit, removed and put the others back in - leaving the culprit out for now.
Now have a roof (handy now the sun is out), indicators radio and sat nav. The two issues we are still yet to see are no steering wheel or windscreen washers, so suspect the issue lies with one of those.
Very happy Jamie today!
- enuff_zed
Electrical issues.
Are you happy enough to tell us which pin (and therefore which module) was your culprit?JamieIsf wrote: ↑Fri Apr 12, 2024 3:06 pm Today's Update!
Electrical issues.
No, because I’ve not worked it out yet.
As mentioned above the only two components that don’t work (that I’ve identified) are the steering wheel controls and the windscreen washers. I’ve managed to turn off the airbag light so don’t think it’s the SIM module. A little more investigation required, but getting there.
Electrical issues.
Getting there.
Turns out the windsceen washer issues unrelated - that just needed a new motor as failed during it's 'hibernation'.
So blame may well lie with the steering wheel/ buttons on steering wheel as only identified (could be others non-identified) component not working on car.. Will investiagte further.
Hoepfully others having these errors find this useful in future.
