what part would you like to see made for the z4?
- solo_the_lad
Looking into developing another part, in addition to the intake tube I am making which is still in the works. I want to make something that could be applicable to all the E85 z4's and not just the N52. Right now I am considering a carbon fiber air scoop for the front behind the grille, since the only one on the market is a jenky metal thing (unless you've got one of those Dinan ones from way back). If I made one, it would be properly done. Let me know if anyone would be interested, or if you have something else in mind. Also if someone could verify the air ducts at the front of both preface/ facelift models are the same, that'd be great too.
3.0i z4, every aero mod on the planet, stage 3 intake swap + tune. Remember guys, you can't fail if you don't try.
Onlinebigwinn
Brake cooling ducts like the msport e46 set up?
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
- enuff_zed
Can you make new airbag modules
The sound generator?
- solo_the_lad
This indeed would be a neat part, ill look into it. Are you picturing a duct that just throws air towards the caliper like the e46 one does, or do you mean a duct that is designed to be connected directly to the caliper
- solo_the_lad
what do you mean by this? I am honestly not very familiar with the sound generator component
- solo_the_lad
consider it done.
just give me several years to get a engineering degree
- Rsipad
Personally, I quite like the look and performance gain of the RPI Scoop. Not sure if that was the intake piece you were referring to.
A brake cooling duct would be pretty neat. I know pre-LCI E85s can delete their fog light and run a duct, but, to my knowledge, the post-LCI non-M doesn't really have any options at the moment.
2006 Z4 3.0i (Montego Blue)
Onlinebigwinn
Yeah the first onesolo_the_lad wrote: ↑Mon Mar 11, 2024 12:31 amThis indeed would be a neat part, ill look into it. Are you picturing a duct that just throws air towards the caliper like the e46 one does, or do you mean a duct that is designed to be connected directly to the caliper
EWS Delete PM me
EWS Delete PM me
- kis
Some sort of lifetime expansion tank. The plastic ones self grenade every few years… AFAIK Mishimoto did a aluminium one for the e46? So similar concept.
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- enuff_zed
solo_the_lad wrote: ↑Mon Mar 11, 2024 12:34 amconsider it done.
An open air filter unit, with heat shield, that isn't silly money
When I had the 350z they did these for about £85, obviously no performance enhancement but looked good in the engine bay and made a great sound!
Currently BMW Z4 E85 3.0si
Previously
BMW Z4 E86 3.0si
Vauxhall VX220 Turbo
Toyota Celica ST205 GT4
Nissan R33 Skyline GTST
Vauxhall VX220 NA
Nissan 350z
Previously
BMW Z4 E86 3.0si
Vauxhall VX220 NA
Nissan 350z
- solo_the_lad
- solo_the_lad
like the AFE but less $$ is that what you're getting at
