IIRC it's 30mm and a thin-wall socket is needed or grind some metal of an old/cheap one. Go back and look at Steps 6, 7 and 8 again. You have to mark the nut, loosen it and carefully count how many turns until it can be removed. Upon reassembly wind it back on the same amount of turns until your marks line up. Fit a new securing washer and stake it into the 2 opposite indents.JordanSecure wrote: ↑Mon Mar 25, 2024 2:31 amHey, quick update.
I have the car on blocks, and the drive shaft dropped. For future reference, the ribbed torx screws (x4) that secure the drive shaft to the differential input are torx socket size E12
I am ready to grease the input flange, but I need to remove the differential input nut first. There is not much clear information on the size or torque required for this nut.
I measured it and it seems to be around 1 3/16" which lands closest to 30mm
Nut:
Any idea about the torque or size for this nut?
Any help is greatly appreciated!
BMW E85 - Drive Shaft Clunk on Acceleration - Replacment Part Quality Question
- patriot66
- JordanSecure
Dear Patriot66patriot66 wrote: ↑Mon Mar 25, 2024 9:19 pm IIRC it's 30mm and a thin-wall socket is needed or grind some metal of an old/cheap one. Go back and look at Steps 6, 7 and 8 again. You have to mark the nut, loosen it and carefully count how many turns until it can be removed. Upon reassembly wind it back on the same amount of turns until your marks line up. Fit a new securing washer and stake it into the 2 opposite indents.
I have finally completed the repair, thank you for all your help through this procedure! The information you provided really helped me complete this project.
The car now is very quiet and no more clank!!! I will see how long this lasts. Please take a look at this thread I just created about the whole procedure, parts, tools, greasing, and more! viewtopic.php?t=146371
Thank you again!!
- patriot66
Good news ! Happy to help and glad you got it sortedJordanSecure wrote: ↑Wed Mar 27, 2024 5:51 pmDear Patriot66patriot66 wrote: ↑Mon Mar 25, 2024 9:19 pm IIRC it's 30mm and a thin-wall socket is needed or grind some metal of an old/cheap one. Go back and look at Steps 6, 7 and 8 again. You have to mark the nut, loosen it and carefully count how many turns until it can be removed. Upon reassembly wind it back on the same amount of turns until your marks line up. Fit a new securing washer and stake it into the 2 opposite indents.
Thank you again!!
