Trying to remove the seats, heated and electrically adjustable.
I can see a big yellow chunky connector to the seat from the body.
Any idea how it unlatches?
How do you disconnect the power harness to the seats?
- B21
- Jollyjoiner
How do you disconnect the powr harness to the seats?
As far as I can remember when I did mine the yellow connector just held the two black plugs in place and acted like a sleeve, I think
2009 35i DCT silver
SLT mapped to 365bhp
If I recall, you slide the connector cover to one side, length wise to disengage.
If it is the same as the Z3 (which is also big and yellow), there should be a black 'sleeve' on one end. Slide that back away from the connector and it unlatches the two connectors. They will then separate on their own. If it looks like the one in the attached picture (not the best admittedly
I am becoming somewhat of an expert on the myriad of overly-complex wiring connectors in a BMW!
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
- enuff_zed
Yes, if it’s the same as an E85 you get hold of the black section which has thumb grips moulded on it. Pull it out to one side and it has a cam and lug set up which disengages the yellow plug.
You may need to use a flat blade to start pulling the black slider out.
Great description Martin!
I was thinking more "slidey pins" but yours is much better!
F31 320i. Good car.
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
- B21
Thnx everybody for the speedy replies…I’ll try and take a pic and see if it makes sense ..
The Z3 doesn't have grips moulded in, so the e85 was an evolution. The E89 probably has an electrically assisted mechanism and the G29 will be done via an 'APP'.
F31 320i. Good car.
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
