Second visit to a Mini main dealer with the current saga affecting the EGR system on B47 diesel engines..
Eventually sometime later in 2024 maybe 2025 they all will be retrofitted with a revised version.
That’s irrelevant to this point…
Once you’ve had your B47/B48/B58 engine re-mapped..even if you reflash it with a brand new BMW supplied code it will always show it was re-mapped..forever..
Well don’t remap your G29….that is if you want to preserve your warranty
- B21
- IMG_2209.jpeg (90.9 KiB) Viewed 448 times
- 1536Z4
That does surprise me as I would have thought that the official map would have overwritten it . You say if you re-flash it . I take it BMW supplied the official map but did you re-flash it or did they . There maybe something BMW do before overwriting it so that it shows it has previously been re-mapped to get out of any warranty issues ?
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
- Phoenixboy
So i assume if you take out a warranty on a G29 and then get it remapped, it will invalidate the warranty?
E89 s drive 30i manual/gone
space grey
Carbon interior trim
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
Gone, E85 Ruby Black.
space grey
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
- B21
On later engines such as the B47/B48/B58 an irreversible flag is set..unless the re-writes were ALL BMW writes..1536Z4 wrote: ↑Thu Nov 30, 2023 11:42 amThat does surprise me as I would have thought that the official map would have overwritten it . You say if you re-flash it . I take it BMW supplied the official map but did you re-flash it or did they . There maybe something BMW do before overwriting it so that it shows it has previously been re-mapped to get out of any warranty issues ?
On earlier cars there’s a minor bit of forensic work plus what is known as shadow codes, some of which are permanently stored..
- B21
Certainly if you had a power train issue you’d have a problem..various folks argue that for non powertrain issues the warranty should still hold..Phoenixboy wrote: ↑Thu Nov 30, 2023 11:51 am So i assume if you take out a warranty on a G29 and then get it remapped, it will invalidate the warranty?
I guess if you can afford to ride it out without a warranty then you could try your luck..
- 1536Z4
Ok thanks for info
