Yay, another gaptech question
- Rockhopper
I would as well but not on the driveway in this weather
- pvr
Current weather is the type that snaps every bit of plastic that you take out of the car ...
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- tomscott
Sorry I meant 3 goes opening and locking the car not 3 presses on the key. Mine does work with one touch but I have to hold the open key.pvr wrote: ↑Wed Nov 29, 2023 10:47 am But isn't that the way GapTech works? You have to press three times to perform the action? It is a while since I had one (last one in the M), and I don't feel the need to have one now as I have programmed the key to do the open and close from the key (just holding it down). Can't do the one touch, but to be honest 99% of the time the car has the roof down anyway.
So I just checked out the website as I had a feeling mine hasnt been working properly and nothing happens when you three click open on the key.
If I hold the unlock button the roof will go down but it is super flakey most of the time it will stop half way and I will have to lock the car and reopen holding the unlock button and hopefully it will work. If I stop holding the open button at any time it also stops.
If I 3 click and hold it will drop. Getting the roof back up works by holding the lock button but it doesn't shut the windows I have to reopen and do the same thing again.
Obviously not working properly
- pvr
That is wrong as it should never stop with the Gaptech in place. And you should never need to hold any buttons either.
Sounds that possibly one of the wires is not connected properly though.
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- Rockhopper
That sounds like the gaptech isn't working at all and its just the comfort opening thats sort of working.
- tomscott
It was the same when the cables were crimped, it was soldered for that reason and still works in the same way
Need to pull it out and check the wiring
- Rockhopper
What car do you have Tom?
bigwinn,
Im really sorry about the delay! That’s very generous of you - I’m sorted now, but thank you very much for the kind offer.
