The broken exhaust manifold was finally fixed last week (a family bereavement and my original mechanic being seriously unwell too, meant this was delayed for some considerable time). Though annoyinly in the process of welding, the garage have busted one of the O2 sensors. It's going back to fix that next week.
Whilst in for the exhaust work, I also got the garage to change my broken oil level sensor.
I've given it a good drive, including full throttle on both normal and sport mode several times, and although it's still (from cold on start up) throwing the intermittent cylinder 2 misfire (and now the 02 sensor) codes, I've not had the codes below, nor the violent limp mode, that I had prior to fixing the air intake, changing the MAF and replacing the oil level sensor.
- 27C3 DME: Thermal oil-level sensor
- 281D DME: BSD generator : signal
- 28A2 DME: Air path:monitoring
- 5E19 CAN data fault from DME/DDE (DSC lamp on as long as error is present)
