Dent Removal Technique
Re: Dent Removal Technique
Seen this type of video before. Never seen a PDR guy use this method, but see how it could work. Would love to see it first hand.
Z4MC Imola red
- doane2u
I did some searching on Youtube, etc., and the conclusion seems to be that this only works temporary and the dent returns? BTW the link at the beginning doesn't work anymore, I know, it's old. When I first found this I was hoping it might be a solution for me as I have a couple of small dings on the car that look sort of like hail damage. Oh well...
- doane2u
I have several small dents, bebe shot size, they almost look like hail dents. I saw a video on Youtube where they are using these little discs that are different sizes to match the dent size. Then they put some sort of glue on it and use a machine, similar to a gear puller to pull the dent out. Next they put a dissolving fluid on the glue which loosens it to peel off the glue and the dent is pretty much gone.. seems to usually take a couple of tries. Has anyone had any experience with this system?
See this video: http://www.bing.com/videos/search?q=aut ... FORM=VIRE1
Hi
the only problem with the dent lifter is that you can lift it too high
turning your low spot into a high spot.
the glue is hot glue from a glue gun.
and rubbing alcohol is used to remove the glue.
wurth do a set but its pretty expensive.
you can have a look on eBay for a Chinese set
http://www.ebay.com/itm/Yellow-Dent-Lif ... 1202566710
to be on the safe side
id search for your nearest PDR tech (paintless Dent Removal)
- doane2u
I ended up paying a guy who has a mobile dent removal service. He came out first and gave me an estimate and it sounded reasonable. His name is TIP with "Perfect Touch" in Monterey, CA.
Well, I'm sort of amazed.. almost every dent has been removed and 90% of them would be impossible to find now. I don't know how he did it but it's almost like magic. The car looks so much better it's amazing and it wasn't terribly expensive.
His technique was to go in from the back side and push the dent back out. He had to remove tail lights, door panels, wheel well panels, etc. to do it, but he's been doing it for 20 years and know just how to get at them.
- Ewazix
Unfortunately I understand that this cold technique is nonsense, it could theoretically work on a minor dent where there has been no 'stretch' in the metal and it is simply 'dimpled' inwards, but those are exactly the sort of repairs that can be 'popped' (probably with your finger!) leaving an undetectable repair anyway and I have seen that done. I'd challenge anybody to claim first hand sight of this cold technique working?
Coincidentally I picked up my wife's car from my trusted dent and scratch magician yesterday. He's done stuff for me for about 10 years and will always give a % estimate of the quality he thinks he can achieve according to the nature of the 'injury'. In this case a nasty shopping trolley dent courtesy of an unidentified cretin had caught and 'stretched' the metal. He estimated a 95% repair or it would require the door and blend-in respray along the side (its a tricky light pearl silver). I'm happy with the result which can only just be seen once pointed out and in the right light but is probably nearer 98% undetectable. At a fraction of the price of a major re-paint I'm happy.
AFTER
AFTER
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
- doane2u
Yeah, it's pretty amazing what they can do. Of the 15 or so small dents I can only barley see a few of them and it's only because I remember where they were.
Link no longer seems to work...
2008 E85 2.0 Exclusive Roadster
Stratus Grey
Based in West Kent
Full Carly diagnostics and coding
Stratus Grey
Based in West Kent
