Battery going flat
Clw
Battery going flat
Post by Clw » Thu Jun 08, 2023 4:40 pm
Hi guys I’m new to this site and looking forward to speaking to you all cheers
Clw
Battery going flat
Post by Clw » Thu Jun 08, 2023 4:44 pm
I have got a z4 3li
Clw
Battery going flat
Post by Clw » Thu Jun 08, 2023 4:46 pm
I took my car to a specialist and he said that the gm4/5 under the glove box needs replacing cost of £600 from bmw any help would be appreciated thanks
Clw
Battery going flat
Post by Clw » Thu Jun 08, 2023 4:48 pm
Z4 2004
Mr Tidy
Battery going flat
Post by Mr Tidy » Thu Jun 08, 2023 5:30 pm
Welcome to the forum. :thumbsup:
It might be worth editing the header to your thread to something like "Wanted GM5 module for 2004 E85" as there are a few people on here who break Z4s from time to time, and depending where you are may be able to help you replace it.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
enuff_zed
Battery going flat
Post by enuff_zed » Thu Jun 08, 2023 5:33 pm
Clw wrote: Thu Jun 08, 2023 4:46 pm I took my car to a specialist and he said that the gm4/5 under the glove box needs replacing cost of £600 from bmw any help would be appreciated thanks
Welcome aboard.
Why do you think the GM5 needs replacing? What are the symptoms?
You can remove it and send it off to a company that will repair it for around £45. If it is a 'Star12 Low' version it will cost a little more.
It is also possible to swap in another one. The only differences will be if yours has had any extra coding done, but that can be sorted on a replacement one anyway.
May be worth getting hold of a second-hand one first and seeing if it fixes the problem.
Whereabouts are you?
A few people like me dotted around who could help you out by providing and fitting a replacement module.
HQ of 'Norfolk Zed Rescue'.
enuff_zed
Battery going flat
Post by enuff_zed » Thu Jun 08, 2023 5:34 pm
Mr Tidy wrote: Thu Jun 08, 2023 5:30 pm Welcome to the forum. :thumbsup:
That is a very good point as you don't mention anything about your battery? Be very odd for the GM5 to be flattening that?
Clw
Battery going flat
Post by Clw » Thu Jun 08, 2023 5:47 pm
Nice one mr tidy I haven’t got a clue how to post anything at the moment I have just joined . I m from Cardiff . The problem I have is this gm5 module is drawing the battery the bloke said after testing it . First of all the alarm kept going off in the night then the battery was going flat after a week of not driving. I’m pulling my hair out mate . Thanks for the reply
Clw
Battery going flat
Post by Clw » Thu Jun 08, 2023 5:51 pm
Also thank you lifer for your reply mate
enuff_zed
Battery going flat
Post by enuff_zed » Thu Jun 08, 2023 6:07 pm
Clw wrote: Thu Jun 08, 2023 5:51 pm Also thank you lifer for your reply mate
Lifer is a 'rank'. Not my name but never mind. :D
The alarm going off could well be the bonnet switch, at the back of the engine bay between the two brace bar mounts. Try disconnecting that and see if it makes any difference.
For the battery drain check there are no lights left on. A favourite is the one inside the centre storage behind the seats. If the lug on the door snaps off it doesn't operate the micro-switch to turn the light off.
Also bear in mind that the cigarette lighter is permanently live. it doesn't switch off after 15 minutes like more modern cars do. So don't leave anything plugged in to that.
But even if it is the GM5 you should only be looking at about £50 outlay to either swap it or get yours repaired.
Luckily for you, umfaan is not far away from you. He has shed loads of spares and could probably help slave in another GM5 to see if that cures it.
Clw
Battery going flat
Post by Clw » Thu Jun 08, 2023 6:13 pm
O I am sorry Enuff thank you for your reply I will try this and see if it solves the problem cheers mate
Umfaan
Battery going flat
Post by Umfaan » Thu Jun 08, 2023 6:27 pm
Hi Clw…….I’m in Pontyclun …will private message you my WhatsApp number.
Clw
Battery going flat
Post by Clw » Thu Jun 08, 2023 6:28 pm
Thanks mate tidy
BlackBee
Battery going flat
Post by BlackBee » Tue Aug 08, 2023 10:45 pm
Hi Clw, did you fix the battery problem and what was the root cause? I'm having the same problem with Z4 E85 that's being attributed to GM5 module.
redgum
Battery going flat
Post by redgum » Wed Aug 09, 2023 1:05 am
I have been chasing the cause of a battery drain issue on my E85 and looks like GM5, sending it off in the morning for repair, a bit fiddly but not so bad to get out and several online fixers for around the £50 mark. When I get it back and fitted back on I will update.
