Hi everyone, just changed oil and filter on my E89 3.0Si. Filled with 6.5 litres of oil. I have driven the car approx 15 miles and the oil temp has got up to 110 but the level indicator is still blank. Has anyone else had a similar thing happen after an oil change and if so does the oil level indicator sort itself out……….?
Many thanks
Oil level indicator reading zero oil after oil change
- Pecky1964
OnlineB21
I’d keep calm if you’ve put the correct amount in…just drive it a couple of times..it’s pretty fickle sometimes..mine panicked when I left it sideways on a 10 degree slope with dire warnings of no oil..
I’ve seen the level vary from 1/2 to full after drainage in the first few miles..
- Pecky1964
Thanks for the reply, I drove it next day and after about 6 miles the gauge confirmed the engine had the correct amount of oil in
OnlineB21
