Weak seat belt retractor
Driver side seat belt retractor very weak. Have to play with it every time I get out of the car to get it to retract. Any relatively easy fix for this?? No other related issues
Have you tried slowly pulling it all the way out and feeding it back in a few times
Last Carbon Black E86 rhd off the production line. 2/8/08 build. 2009 09 Registered.
- DMike
After cleaning my seat belt (apc & mf), noted that as a side effect it slides and rolls in a bit better.
2005 Z4 3.0i Sterling grey
- tug
Pull the belt all the way out then spray liberally with Mr Sheen then rub in with clean cloth. Pull in and out a good few times, it works a treat.
E85 N46 2.0i SE BLACK SAPPHIRE
- colb
Belts get dirty over time, pull it out fully and clean it with a damp cloth and some soapy water, let it dry and see if it retracts any better, use Mr Sheen on it if its still slow then test it again.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1998 Honda Deauville 650
1999 1.8 Z3
2003 2.5 Z4
