DISA Valve Replace or Rebuild? What's the consensus? ANSWERS
Hey all
I'm doing a lot of engine work on this 2005 2.5i I bought recently. I read that the DISA valve is a time bomb waiting to destroy your engine, so I plan to replace it.... OR, should I rebuild it?
I already ordered the Vaico brand from FCP Euro for $135 USD, although I can send it back if the consensus is to rebuild or buy a different brand.
Any thoughts appreciated!
Current: 2005 Z4 2.5i: first time to own a BMW and loving it!
Previous: 2018 Chevy Volt / 2004 Acura RSX Type S / 1989 Acura Intergra RS / 1982 Ford Escort / 1968 VW Bus
Easy job to rebuild with a kit Studio, will be cheaper than replacing the whole unit. Kits like this one are around £60 last time I did one in the UK, no idea in the states but surely a fair bit less than a new unit. Whichever way you go it's a pretty essential job so neither is wrong.
- dis.jpg (45.53 KiB) Viewed 792 times
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
Could I use that kit to upgrade the Vaico unit I just ordered? I feel like I read somewhere that one of the upgrade parts companies said their upgrade only works on OEM parts, not Vaico. But, if the Vaico part is overall good AND I can update... that seems like a no-brainer to me.
Also, how can I tell if the DISA unit on my car is OEM or aftermarket? I bought this car recently and I have no idea if the DISA unit has ever been changed or not.
- MikeyH
The x8r is aluminium and the oem is plastic. I think that’s correct
I can't say for 100% but I can't think of any reason why an upgrade kit like the X8R wouldn't fit your Vaico unit, they all use the same construction method. As Mikey says an upgrade like this is made of aluminium, also the main difference and the most important is the upgrade kit uses a full threaded rod for the valve instead of the pin on standard units which is the part that comes loose over time and can be drawn into the inlet manifold, then into a combustion chamber causing either, piston and cylinder head damage, bore scoring, or both. Pretty essential to change or upgrade the disa as you're doing imo.
Hope that's of some help.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
I just put in a call to the X8R manufacturer - I left them a message. I'll pass on what they say as to whether I can use the upgrade kit on a Vaico unit.
I messaged another upgrade kit maker on Ebay and they said there's is NOT compatible with a Vaico unit. I wonder why....
I reached out to GAS and they said no aftermarket DISA units are compatible with their upgrade kits. He told me that it's because the aftermarket ones have slightly different tolerances and clearances where the flat rotates resulting in the upgrade flat getting stuck or moving incorrectly. He said this is definitely true with the Vaico unit. He said he's not aware of ANY aftermarket unit that works with the upgrade unfortunately.
I also posted a question on the X8R page on Amazon (which is a company called LRNJ Parts) and got a VERY long response, which I suspect is an automated response. In a nutshell it says that their upgrade kit will work in any OEM unit that meets all specifications of a genuine DISA unit. So, I'm going to deduce that their upgrade will NOT work in the Vaico unit.
I think I'm going to have to buy a used DISA unit on Ebay. I could also buy a complete DISA unit from GAS which is very expensive at about $450 USD.
My mechanic didn't think it was necessary to be so "careful" about it. He said that pin shouldn't be able to come out unless you drop it accidentally when removing it. I don't know... I've seen other posters suggesting that part where the pin is may have essentially disintegrated and the pin flew into the engine causing immediate destruction. $450 now or $4500 later? Hmmm......
Thoughts?
Thoughts?
- Chris_D
Although I've heard many anecdotal stories and theories about the DISA 'grenading' an engine I've actually yet to read/hear about an actual or documented incident.
I'm all in favour of preventive maintenance, but really only when it's totally warranted.
Anyone have any documented or photographic proof of damage/borked engine because of a failed DISA?
I doubt it.
I doubt it.
Mine was loose as a tarts drawers Studio....why take the chance...?
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
Proof Kay.....Chris D modelling them....
- gettyimages-93217660-612x612 (1).jpg (74.1 KiB) Viewed 658 times
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- MikeyH
Picasso was a drawer of tarts
- Chris_D
I was simply trying...and failing miserably to emulate your fabulous look John: I won't ask where you retrieved those accessorising carrots from John, I think we can all guess. ew
You guys are hilarious! haha
