Roof failure in essex
Hi all,
Unfortunately my Z4 has succumb to the dreaded roof failure,the front catches unlock and the motor winds,but the roof doesn’t lower.Is there any one in the Essex area that can repair/replace said motor.I am based near the Dartford crossing.
Thanks in advance.
Phil
Thanks in advance.
Phil
- bigwinn
I think either RBM Hampshire is close, as is Martin
Depends how quickly you need it sorting!
however the latter may be otherwise engaged at presentenuff_zed
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
Thanks bigwinn for the swift reply and suggestions.
Phil
Phil
- enuff_zed
Phil,
I’m back from St Lucia on 1st June. If you can wait until then???
Enuff-zed,
That would be absolutely fine.Just let me know the details.Weekends would be perfect.
Thanks for responding.
Regards
Phil
Regards
Phil
Hi mate,
The only thing is I am due to go into hospital at very short notice for approximately a week or more,so unfortunately if I get called we will have to reschedule.I hope that is acceptable.
Regards Phil
Regards Phil
- enuff_zed
Well if it’s closed and watertight then get yourself sorted first. Send me a reminder 2/6 or after and we can discuss.Mr Goodkat wrote: ↑Mon May 22, 2023 11:42 am Hi mate,
Regards Phil
Yes it’s all closed a sealed fine.I will contact you on 2/6,as suggested.
Thanks so much.
Phil
Thanks so much.
Phil
Hi,Enuff_zed,
Hope you enjoyed your break in St Lucia.
Please let me know when is convenient for you to fix my roof,as I said weekend are best for me.
Regards
Phil
Regards
Phil
- enuff_zed
Hi Phil, just got back yesterday. Flippin' cold here isn't it!Mr Goodkat wrote: ↑Fri Jun 02, 2023 2:00 pm Hi,Enuff_zed,
Regards
Phil
I'll PM you my contact number as it'll be easier to sort something by phone.
- enuff_zed
I'm sure others such as bigwinn, or Number5, will offer their thoughts too, but if you can still here the motor running but the roof doesn't move then I'm thinking:
1. Pump failure
2. Manual release ring pulled and now seized
3. Hydraulic leak!
Number 3 being the worst case as it is most likely to be a pipe split, but could conceivably also be a leaking ram. Let's hope it's 1 or 2!
Either way, until the motor is in the boot we won't know any more detail.
Were there any signs before it failed?
Did it move slower in either direction? Has the red ring been pulled? Any sign of oily residue on the ground just on front of either rear wheel?
1. Pump failure
3. Hydraulic leak!
- bigwinn
I concur I predict a combination of 2 and low fluid- had one in the week that once topped up and freed off was fine and dandyenuff_zed wrote: ↑Fri Jun 02, 2023 4:16 pm I'm sure others such as bigwinn, or Number5, will offer their thoughts too, but if you can still here the motor running but the roof doesn't move then I'm thinking:
1. Pump failure
3. Hydraulic leak!
EWS Delete PM me
EWS Delete PM me
- enuff_zed
I hope that's the worse case!!!bigwinn wrote: ↑Fri Jun 02, 2023 5:24 pmI concur I predict a combination of 2 and low fluid- had one in the week that once topped up and freed off was fine and dandyenuff_zed wrote: ↑Fri Jun 02, 2023 4:16 pm I'm sure others such as bigwinn, or Number5, will offer their thoughts too, but if you can still here the motor running but the roof doesn't move then I'm thinking:
1. Pump failure
3. Hydraulic leak!
I had one recently that would not work like that.
I got the motor out to discover it had only just been replaced but put back in it's original position.
They had topped the reservoir to the '+' mark, then rebuilt everything. Must have had the roof off to do it I reckon.
Anyway, all rebuilt and hidden away and of course the first couple of operations bled the pipes, after which the fluid level had dropped too far to work.
At least the owner was happy I only had to move it and top it up.
