High output from alternator
Onlinez4lincs
So... first little issue to try and sort with the new E89.
Had it in for a full service yesterday and one of the issues that came up, from what I remember of the guy saying, is the alternator is showing a high output.. like it's trying to over charge the battery. The battery is a Yigit Aku 12V 78Ah 690 CCA
If in fact it is the battery at fault, could it be..
Battery is just old and not up to it
Battery isn't the right one for this car
Battery hasn't been registered??
Any ideas appreciated!
E89 20i (ish) M Sport Valencia Orange
Gone: E85 2.0i, 2.5si & 3.0i
- enuff_zed
How old is the battery?
If its old replace it first.
It probably hasn't been properly registered but the trouble is unless it is new you won't be able to reset the charging cycle to the correct one anyway.
I'd definitely think swap the battery before anything else.
I'll nip out and get the details off mine so you know the correct one to fit.
- enuff_zed
OK, so mine is a genuine BMW one (Varta)
12v 80Ah 800A
Slightly different to yours.
12v 80Ah 800A
Onlinez4lincs
Aha, legend as always Martin!enuff_zed wrote: ↑Wed May 17, 2023 11:14 am How old is the battery?
Is there anyway to tell how old the battery is without seeing when purchased?
Think the lower capacity could be causing issues? The Start/Stop doesn't activate for instance.
You able to register these or is a proper dealer kinda thing?
- B21
Sounds like the battery is on its way out…these cars are extremely susceptible to things going wrong..sometimes badly due to poor battery condition..
Stop/start not working is a sure sign of battery state…
The who-flung-dung name of the supplier does not fill me with confidence…
Strong recommendation..get a battery from a decent supplier and ensure its coded / registered as required
- enuff_zed
Not sure with the E89. I believe if you fit another battery the same size you just tell it there's a new one, but if you change the capacity etc you need to do a bit more.z4lincs wrote: ↑Wed May 17, 2023 11:23 amAha, legend as always Martin!enuff_zed wrote: ↑Wed May 17, 2023 11:14 am How old is the battery?
I do have various software now, but used it very little.
- enuff_zed
Don't forget you need an AGM one too.
- B21
Battery capacity change either way..coding
Change of battery even if same size ..registration..
New battery different size..code then register..two seperate issues..
Coding tells system how much charge can be put into battery how much expected reserves
Registration tells how healthy battery is and what actions to be taken to preserve systems..
Onlinez4lincs
Ok thanks all! Martin, I’ll send you a message!
Onlinez4lincs
Fitted new battery and magically things start working! I think previous owner had stuck in any old thing to get the car running
When I came to register the new one (BimmerLink app) it was still set to what it should be capacity wise, rather than what they'd put in.
Thanks as always for all the input
- enuff_zed
Excellent. So that would explain why the alternator was throwing out a bigger charge.z4lincs wrote: ↑Sat May 20, 2023 8:57 am Fitted new battery and magically things start working! I think previous owner had stuck in any old thing to get the car running
And now I know a man who can register/code E89 batteries.
Onlinez4lincs
Register yes.. thankfully didn't need to code as they helpfully put that ability in a different app that is another chargeenuff_zed wrote: ↑Sat May 20, 2023 9:00 amExcellent. So that would explain why the alternator was throwing out a bigger charge.z4lincs wrote: ↑Sat May 20, 2023 8:57 am Fitted new battery and magically things start working! I think previous owner had stuck in any old thing to get the car running
