Bilstein b4 or b6
Bilstein b4 or b6
Looking to replace my struts and shocks. Don't really want any firmer as it's pretty firm with stock shocks. Also dont want lower. What is the experience of the forum?
- Rockhopper
Bilstein b4 or b6
As a general rules shocks don't control the height of the car, that's down to the spring length. But - do you actually have an M?
Online
Bilstein b4 or b6
Unless I'm mistaken you can't get B4 for the Z4M, only B6. And, as above, ride height is determined by springs.
Bilstein b4 or b6
Yes have M. My bad on the shock ride hight.
What do people generally replace Oem shocks with on these? My understanding is that b6 is about 20% firmer than OE which will surely hurt low speed ride quqlity.
Mine is great at speed and well controlled but pretty bad round town over bumps etc. Looking to improve that without compromising control at speed.
- Argenta
Bilstein b4 or b6
Eibach Pro springs made mine a lot more comfy in general (and lower obviously) but I'd imagine with Billies you also get more control, they're the best.
Bilstein b4 or b6
40%ish off today at autodoc. I'm hoping to grab a set for my car. Just to add to the list of parts and jobs I've got planned for the car
- Dubbedown
Bilstein b4 or b6
Don’t go B6, everyone and their mother loves to quote monotube lifetime warranty shocks but they ride like crap on any road surface that’s less than perfect. I’ve run multiple setups and for a non-track car, nothing beats fresh OEM hardware imho.
Follow latest mods on Imolarot_S54 M Coupe OEM+
Online
Bilstein b4 or b6
Have you driven actually driven a standard Z4M with it's very strange/poor suspension set-up?
- Argenta
Bilstein b4 or b6
B6's are top quality stuff, should make a huge difference especially on a Z4M
- Dubbedown
Bilstein b4 or b6
Yes, I currently own 2 M’s (roadster and coupe).
A lot of people write off the factory suspension because they never had the pleasure of owning the car new. So of course when picking up the car secondhand, a tired worn suspension will leave a lot to be desired. The factory struts typically need to be replaced every 50-60k miles. But do an apples-to-apples comparison, and you’d be surprised how good the factory setup is with fresh struts, bushings (fcab rtab, etc), and mounts.
The only time I noticed my coupe understeers is on track during high g corners. But you could never replicate this scenario on any public road, and no off-the-shelf strut like the B6 will remedy this. For the 99% of usage, my coupe with fresh stock hardware handles feels amazing and I will gladly make that trade-off.
To put things in perspective, I am currently in putting my M roadster back to stock so I can list it for sale. It has full aftermarket suspension upgrade but the component I am keeping is the CSL front sway bar to help address the 1% scenario above.
I equate the B6 to a “high-performing” all season tire, i.e. an upgrade in some ways but also a compromise in many. For a sport shock, it does okay but not great on track. For street, it performs nicely on the most perfect road conditions but it’s overly harsh for anything else. Whereas fresh factory hardware is like a Michelin PS4S - it’s fantastic under most conditions and can even handle the occasional track day. However, if you wanted anything better, you might look to a 200tw or R-comp though they won’t last as long (i.e. bringing back to struts, it will need more frequent rebuilds).
The only time I would recommend Bilstein is if you went with their PSS 10 coilovers AND swapped for custom linear springs. But at that point you’ve shelled out enough money you’re not far from getting a higher tier single adjustable setup.
- Dubbedown
Bilstein b4 or b6
See this thread here
viewtopic.php?t=138219
Owner upgraded his badly worn stock suspension (with broken springs) for thr B12 kit, which is essentially the B6 struts with Eibach springs (specifically designed to be paired with B6 struts). Yet it didn’t take long for him to realize they’re too harsh and quickly swapped them out for an entry level coilovers. No knock against the BC system but just goes to show how the defacto Bilstein B6 upgrade comes with a lot of caveats.
But if it wasn’t obvious, my recommendation is if you’re sticking with factory springs, go with B4’s which are OE equivalent.
Bilstein b4 or b6
Thanks for the feedback. I was afraid b6 at 20 % firmer would be like that. Bilstein don't seem to make a oem equivalent so who to choose? Buying from bmw will be expensive.
- Dubbedown
Bilstein b4 or b6
In general the B4 is a direct OEM replacement. B6 are valved firmer but meant to be paired with factory springs. B8’s are same thing as B6 but meant for lower aftermarket springs.
I know the B4 is offered for the non-M but I don’t recall seeking one for the M. But since your original post specified not wanting to go lower nor make the ride any firmer, seems like OE is your best bet.
- 3gGT01
Bilstein b4 or b6
Do we know who makes the stock Z4M struts?
2007 Z4MC Interlagos Blue Metallic w/Light Sepang Bronze Nappa interior. 'Emma'
- Rockhopper
Bilstein b4 or b6
Sachs i would think.
