Soft top issue
Stanat43
Soft top issue
Post by Stanat43 » Tue May 09, 2023 3:36 pm
Good afternoon all.
Finally bought my dream car. Z4, driving like a dream however I’ve encountered an issue with the soft top.
Goes up and down without problems. However when down the red warning light continues to flash and side windows don’t move back up as o believe they should.
Q: is there a straightforward fix for this issue?
Steve
Cheshire East
DMike
Soft top issue
Post by DMike » Tue May 09, 2023 4:30 pm
Hi and welcome to the forum! There are way more knowledgeable members who’ll chime in with diagnostics and more, but I’ll start with a few simple ones first: When opening the roof, after the roof is down, did you keep pressing the open button for five more seconds? And when the roof is up, tried doing a window reset?
2005 Z4 3.0i Sterling grey
bigwinn
Soft top issue
Post by bigwinn » Tue May 09, 2023 4:46 pm
Hi Steve
Check that the roof is going all the way down- it may be fouling on the soft top catch and therefore not making a connection with the hall sensor?
Try giving it a push with your hand to see if it latches into place
EWS Delete PM me
Coding- airbags etc PM me
Stanat43
Soft top issue
Post by Stanat43 » Wed May 10, 2023 11:37 am
Many thanks for this advice,I’ll give it a go.
Quick query: what’s a window reset, I can’t find details in the ( limited) information that came with the car?
Cheers all,
Steve
Stanat43
Soft top issue
Cheers all,
Steve
enuff_zed
Soft top issue
Post by enuff_zed » Wed May 10, 2023 11:47 am
Stanat43 wrote: Wed May 10, 2023 11:37 am Many thanks for this advice,I’ll give it a go.
Cheers all,
Steve
If the windows drop a few mm when you open the door you should be ok.
If not then the one that's always worked for is:
1. Sit in the drivers seat, windows, roof and doors closed. Ignition on.
2. Hold the switch to wind the drivers window all the way down and when it reaches the bottom release and reselect the down switch 4 times within 10 seconds. You may hear faint clicks in the door.
3. Hold the switch to wind the drivers window all the way up and when it reaches the top release and reselect the up switch 4 times within 10 seconds. You may hear faint clicks in the door.
4. Open the drivers door and you should see the window drop a little.
5. Close the door and it should go back up a little.
6. Check the one touch open and close works.
7. Repeat on the passenger window (you can still do this from the switch on the drivers door)
8. NB. Early models do not all seem to have one touch close on the passenger window, but it should go down one touch.
HQ of 'Norfolk Zed Rescue'.
Stanat43
Soft top issue
Post by Stanat43 » Wed May 10, 2023 12:22 pm
Many thanks for this I'll give it a go!
Best wishes
Steve H
