My driver side window would not go up yesterday. It continued to go down perfectly well using the switch and of course it goes down slightly every time I open the door - but going up just hear a faint click then nothing. So now there is no window to be seen.
I have looked on forum and everything seems to point to regulator. I have taken off door trim but before I tackle the membrane I thought I would check on here whether it could be anything else. There are a few things I have noted from forum posts that I didn't seem to get
- There was no noise (eg popping) just before it happened - at least that I noticed - I was reversing out of driveway
- There is no noise when I pull the window lifter switch - a faint click then nothing
- There was no previous indication of any problem (grinding noise or slow movement)
Steve
