Engine Bay Cross Brace Support Bar Attach Point Broken - Weld?? SOLVED
Hi,
One of the engine bay cross brace support bars has become detached from the body of the car. The bar itself is fine and it's attached to the dashboard side just fine. But the metal tab that's attached to the shock absorber housing (for lack of a better description) is no longer attached.
I thought maybe this could be welded back, but a welder told me it could damage/melt that area and then we'd be in trouble.
I've seen some high-performance mods that might solve the issue easily. Those mods create a triangle and attach to all 3 screws on the housing/hub.
But if I don't go that route, how would I fix this detached piece?
Thanks!
Thanks!
- PXL_20230428_063633777.jpg (132.96 KiB) Viewed 491 times
Current: 2005 Z4 2.5i: first time to own a BMW and loving it!
Previous: 2018 Chevy Volt / 2004 Acura RSX Type S / 1989 Acura Intergra RS / 1982 Ford Escort / 1968 VW Bus
- enuff_zed
Jock156 got his welded but I think they had to drop the strut first. As that affects camber you’d need an alignment afterwards as well.
Onlinejock156
Yup! & not the tidiest weld either
- enuff_zed
I didn't like to say that but it does show up in your otherwise immaculate engine bay.
StudioWizard, unless you can find a really good welder I reckon the triangle brace idea may look a lot neater.
Ask around on here as not sure they all fit every model.
Onlinejock156
Thats what I'm looking at! Ultra Racing seems to be the go to place but they can't confirm it will fit a 2.0L. Their policy is no returns!!!!!
Can anyone confirm either a 2.5L or 3.0L will fit a 2.0L?
PLEASE!
PLEASE!
- enuff_zed
Or you buy one, and if it doesn't fit, pass it on to StudioWizard.
Could be drilled and bolted for a short term fix?
Montego blue 2006 BMW Z4 coupe 3.0si with black interior, ZHP, Whippy, 12mm front/16mm rear spacers on BBS 108's wrapped in Michelin PS4's. :driving:Brand new Pierburg water pump fitted at 101k after failure (should have done it at 100k)
Thats a fairly easy repair for any half decent welder.
Clean up area. Drill hole and plug weld, then seam along the broken edge.
Grind back weld and paint accordingly.
This happens when the car is in the air and the brace gets undone. Then put back on before the car is on the ground.
The force as the wheels touch down splays the turrets and bang the brace brackets snap.
2009 09 Carbon Black Cinnamon E86
- BumpyZ4
I just replaced mine. The replacement one that BMW sells is much beefier as they figured out they had a problem. Plus they are dirt cheap.
2003 E85 3.0i Sterling Gray
KLR 650
Diva Roadster (Kit Car)
KLR 650
[/quote]
[/quote]
Yes, although I live in the US.
[/quote]
- enuff_zed
[/quote]
[/quote]
Oh yeah. Doh!
That's very interesting because I recently took the car in and I think the mechanic isn't super experienced. I bet he did that.... He made some other newbie mistakes, too, that I caught. Arrrgh.j3nks79 wrote: ↑Fri Apr 28, 2023 12:15 pm Thats a fairly easy repair for any half decent welder.
What is the replacement one that BMW sells? Do you have a part number, picture and/or link?
- BumpyZ4
P/N 41007193040 these are much thicker than the original. You will also need to order bolt p/n 07119906010. This link will shows pictures of the new and improved bracket. https://www.ecstuning.com/b-genuine-bmw ... 007193040/
KLR 650
KLR 650
Is that bracket designed to be welded onto the same spot? If so, how do I find a good auto parts welder?BumpyZ4 wrote: ↑Sun Apr 30, 2023 1:12 am P/N 41007193040 these are much thicker than the original. You will also need to order bolt p/n 07119906010. This link will shows pictures of the new and improved bracket. https://www.ecstuning.com/b-genuine-bmw ... 007193040/
Also, would it make sense to remove the other one so I replace both? How do you remove the rest of the broken one and the other one as well?
