Help me identify this part ?
Z4Mariner
Post by Z4Mariner » Mon Apr 24, 2023 11:42 pm
I found this on the floor of my garage after replacing rear springs and shocks on my Coupe. For that job I removed all of the rear boot trim. I figure there are three main possibilities: 1) It's a drain fitting that actually goes into my Z4C boot area (I will look at RealOEM, but that's not sure-fire); 2) It's a drain fitting in the wheel well to my car, and I managed to bump it without without noticing; and 3) It snuck away from my bag of random car parts - which was in the area because I needed to replace one of the interior trim clips . . . . .
Thanks in advance. :D
unknown drain 1.jpg (164.02 KiB) Viewed 351 times
unknown drain 2.jpg (169.58 KiB) Viewed 351 times
Z4Mariner
Minnesota, USA
2006 Z4 Coupe 3.0Si, Montego Blue, MT
3gGT01
Post by 3gGT01 » Tue Apr 25, 2023 2:02 am
That's an interesting one! So it has a hole through the middle of that piece, like a drain? :o
2007 Z4MC Interlagos Blue Metallic w/Light Sepang Bronze Nappa interior. 'Emma'
Z4Mariner
Post by Z4Mariner » Tue Apr 25, 2023 4:11 am
Yes, it's about 45mm long, and the tube has an internal, molded one-way valve design at the narrow end of the tube. I'm leaning toward it being a left-over from something else. The boot interior trim has an indent on each side behind the rear wheel wells - if it was in one of those, I would not have noticed the black-on-black until I pulled the trim and dumped it onto the garage floor. I could not find anything remotely close in RealOEM.
Z4Mariner
Minnesota, USA
skmattwell
Post by skmattwell » Tue Apr 25, 2023 4:30 am
Absolute pure guess but maybe some kind of rubber insert from the radio antenna? To stop rainwater entering the boot (trunk)
Doesn't look massively important anyway :thumbsup:
Z4Mariner
Post by Z4Mariner » Wed Apr 26, 2023 1:38 pm
Thanks all - I'll do one more quick look (especially at antenna) and if no match I'll let it be.
Z4Mariner
Minnesota, USA
3gGT01
Post by 3gGT01 » Wed Apr 26, 2023 1:45 pm
Next time I put mine on my lift I will look for that part. :thumbsup:
3gGT01
Post by 3gGT01 » Sat May 27, 2023 7:12 pm
Z4Mariner wrote: Mon Apr 24, 2023 11:42 pm I found this on the floor of my garage after replacing rear springs and shocks on my Coupe. For that job I removed all of the rear boot trim. I figure there are three main possibilities: 1) It's a drain fitting that actually goes into my Z4C boot area (I will look at RealOEM, but that's not sure-fire); 2) It's a drain fitting in the wheel well to my car, and I managed to bump it without without noticing; and 3) It snuck away from my bag of random car parts - which was in the area because I needed to replace one of the interior trim clips . . . . .
Thanks in advance. :D unknown drain 1.jpgunknown drain 2.jpg
I had my ZMC on the lift and I searched for this part, but did not find it. Must be there someplace where you had things apart... :headbang:
Z4Mariner
Post by Z4Mariner » Sun May 28, 2023 9:38 pm
Thanks 3gGT01 - that's my thought, and I'll get over my OCD and move on :thumbsup:
Z4Mariner
Minnesota, USA
